View Full Version : Engine, Transmission and Drivetrain
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13
  1. lash adjusters/lifters - hydrolic or solid?
  2. tuning shops?
  3. Synthetic Oil
  4. Stupid SAFC Question
  5. New downpipe
  6. Motors out lol
  7. 1990 eclipse engine swap
  8. Engine Swap - 1990 Mitsubishi Eclipse
  9. Clutch is finally goin...
  10. How do u get the crank *sproket* off?!?
  11. 50 trim setup
  12. Time to Make a Decision.
  13. Dodge Neon R/T Mopar Performance ECU...feasable on a 2GNT?
  14. water temp sensor
  15. Easy Non-turbo to Turbo swap for 1g's.
  16. 7 bolt rebuild
  17. DSMlink help... ASAP!
  18. Fuel upgrade?
  19. Front Mount Intercooler Kit
  20. What do you guys think?
  21. Underdrive Pulley
  22. My HP estimation
  23. 560 hp on 550cc injectors? lol
  24. 2.3 strocker
  25. Turbo question
  26. intake
  27. Where to now?
  28. Which tires
  29. what to do
  30. NEED HELP ASAP Motor Build (Rods/Rod Caps)
  31. Need Transmission Now
  32. 14b turbo install?
  33. Axles help
  34. need some opinions
  35. Clutch install
  36. Catch Can
  37. crashed car coolant is foamy
  38. What is A/R, Trim, diffrent manifolds?
  39. Race gas and 93 octane difference
  40. Need advise
  41. smic vs fmic
  42. Camshafts
  43. Best clutch
  44. Estimation on HP?
  45. If u love Dsm you will read an help
  46. 98 GS-T please help!!
  47. turbo 4g64
  48. Iridium or not to Iridium
  49. types of turbos
  50. 92 Eclipse GS help plz
  51. Tranny fluid...
  52. HKS 280 Cams
  53. Fuel pressure gauge install
  54. stock 99 gs 1/4 mile times?
  55. Blew my head gasket today...
  56. Head rebuild time
  57. Thought of tonight... bastard 20g
  58. Breaking in Head
  59. cheap 4g63nt mod
  60. Cutting a splash wall
  61. S-AFC II Installed
  62. A couple of Questions¿
  63. 4g63 vs. 4g64
  64. High Performance Parts for your 4G37!!!
  65. Clutch Options
  66. What Clutch
  67. why get big brake kit?
  68. Race gas, 93oct pump gas + MOTH BALLS??
  69. this thing got good reviews.for us a/t guys
  70. Building a head.... suggestions? help?
  71. Accessory removal... PS and CC
  72. Drove a weak GSX
  73. What size of wastegate is necissary ?
  74. turbo an automatic
  75. Whistling TB... aka "Non-turbo BOV"
  76. turbocharging a 420a
  77. location of engine number
  78. so would these be the right mods?
  79. stock bov
  80. Before Attempting to install an Underdrive Pulley (420A)
  81. 'How to remove ecu pins'
  82. Electric Cutout
  83. diff between 2g eclipse and evo 8
  84. boost and stock interals
  85. suspension problem
  86. OEM vs. Autozone
  87. turbo help
  88. Pulling engine... almost out, a few questions
  89. quick question
  90. Always, turbo Question.
  91. Data logger HELP!!!
  92. turbo timer stopped working
  93. Caved and bought a FMIC
  94. Advantages of BS removal?
  95. TunerStein/Palm-n-Stein?
  96. engine swap
  97. Safc
  98. Ground to trigger stutterbox? Wiring help?
  99. non turbo to turbo
  100. 14b turbo
  101. 14b turbo
  102. Major BOV problem
  103. IMportant please answer!!!
  104. Compressor surge??
  105. 14b turbo
  106. 6 bolt swap into a 2g writeup
  107. help quick plz?
  108. 92 talon tsi
  109. 6 Bolt & 7 Bolt Info Needed
  110. (4G37T) I've got all the parts, now how much boost???
  111. HP estimate
  112. My first upgrades (help) dont hurt me with words :(
  113. J-pipe
  114. j-pipe
  115. Greddy Boost Controller Question
  116. piston selection help
  117. Help Plz
  118. can i fit an evo engine in my eclipse
  119. Clutch Fluid
  120. its safe to clean Intercooler using vfaq method ?
  121. Buying an eclipse
  122. 4g64 care
  123. Racing....let me hear your stories
  124. bov/intake hose
  125. How to change awd to fwd in a 2G 5 spd?
  126. Rubber coating on intercooler pipes?
  127. rebuilding the 7 bolt
  128. im going against a rx7...twin turbo...
  129. engine swap
  130. OEM part number
  131. 1995 Setup what do you think?
  132. 14b to 13g swap
  133. kpa to psi
  134. 4g63t all the same?
  135. Cold Air Intake & eBay
  136. upgarde path i want to take...yes or no?
  137. Any one here running small oil filter on their 2g ?
  138. Syncromesh vs Syncroshift
  139. 97 eclipse engine conversion
  140. dsmlink?
  141. Warning....Magnus Motorsports
  142. pistons
  143. whats the best rods,rings and pistons?
  144. have evo 3 16 g where next>>>
  145. upgrade list>>>
  146. 14b performance....
  147. What is good place to buy Mitsubishi brand belt ?
  148. Quick question
  149. Head Rebuild... Part 2
  150. Convert fwd to awd
  151. im so lucky
  152. Which springs are for front and back???
  153. psi level
  154. 91 talon... BUY OR NO BUY?
  155. Driving to mich from IL
  156. N1 downpipe options
  157. Big Brakes vs. high performance pads/discs
  158. Any one here use, fuel filter instead oil catch can ?
  159. how do you know if center dif is out
  160. starters
  161. Dsm Link and Data log
  162. more boost
  163. I need help with a boost controller...
  164. Setting ignition timing with an aftermarket UDP
  165. Transmission Help
  166. What is...
  167. Radiator help...FMIC causing overeating
  168. lsd insersts? are they worth?
  169. motor mounts
  170. Best Spark Plug FAQ for DSM !! ( Thanks MrBoxx )
  171. How to install a Rear Strut Bar?
  172. 1995 engine swap
  173. 1995 Talon ESI w/ Bad engine, would a 4G63 bolt in?
  174. My head rebuild... Part 1
  175. Link'n it up!
  176. awd and awd/247?
  177. 1g throttle body -help-
  178. I'm back...
  179. Question for all the turboed N/Ts
  180. Boost
  181. Questions about the 4g63
  182. auto to 5 speed conversion. need help!
  183. 16G turbo install
  184. Update on my car.
  185. 4g63 n/t clutch
  186. Intake nipple
  187. Upper ball joint removal
  188. Carbon fiber wing
  189. Running a water cooled turbo without the water cooled part. Bad?
  190. Turboing my friend's car
  191. GM MAF MAF Translator HELP
  192. suspension question?
  193. What is the stock fuel pressure?
  194. Is This A Good Engine Rebuild Kit?
  195. Whats the best way to clean carbon buildup?
  196. some 6bolt crankwalk
  197. PCV Valve?? what is it for? Mine has oil on it
  198. transmission oil mix with motor oil?
  199. ebrake question...
  200. 2g NT ?s
  201. short shifter good or no good
  202. bottom end questions
  203. h20/alchy pump location.
  204. Thinking of dropping the A/C
  205. Why is there a ride height difference between turbo and non turbo 2Gs?
  206. Will DSMlink work for a 2.4?
  207. 14b turbo from 1990 tsi
  208. size & type of the 4 bolts from the exhaust manifold to the turbo housing?
  209. Exhaust Manifold to Turbo Housing size & type?
  210. Competition Clutches?
  211. Vac line removal. Help!
  212. Newbie fuel trim questions
  213. Throttle Pulley anyone?
  214. FWD converted to RWD (DOABLE?)
  215. Greddy Type RS BOV help
  216. Does it Work?
  217. Coil-overs
  218. what do you think of this?
  219. Damnit... Got to do tranny
  220. 1g 1.8 & 2.0 N/t tranny ?'s
  221. Plug gap?
  222. help please?
  223. Valve cover Grommets???? what are they for?
  224. Got my Bored TB
  225. Best battery for the money?
  226. The Purple People Eater started! Now I need URGENT help!
  227. DSMlink?
  228. Damn gear oil HELP!!!
  229. smog with a bad turbo!!!!
  230. Pick my setup!
  231. Best engine oil?
  232. Good idea, or no? (FMIC related)
  233. Blown head gasket
  234. injector help!
  235. Buy the cheapest oil? Advise plz
  236. Motor build....HELP!!!!
  237. new parts hook up
  238. Check this Ebay FMIC kit..
  239. Built 420A Auto Trans?
  240. FMIC setups.... help me spend my money!
  241. INSTALLED 650cc injectors and FPR
  242. Finally Did Brakes!!
  243. Timing belt tension question
  244. AWD Rear Suspension
  245. EvoIII cams are they a upgrade for a 2g?
  246. Personal opinion
  247. 300 H.p
  248. Voltage Stabilizer
  249. check this out!!
  250. i think i'm gonna join the 6 bolt club
