Mitsubishi
Eclipse/Talon/Laser
> Engine, Transmission and Drivetrain
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
Ground locations
2 step with DSMlink
Rods
Stock GSX
oil pan problems
ne1 have dyno sheet for gst/gsx with 16g
top speed
94 talon bad idle!!!
got a 92 eclipse and need some pointers
I need help
How to heat car up quicker
Disconnecting EVAP and EGR
help finding backup light switch wiring
450cc fuel injectors
Cast manifolds vs exhaust studs
best synthetic oil for the winter
Transmission problems pls help
Problem with 1991 Eagle
97 eclipse auto trans NOISE
MAF question
1995 Eagle Talon TSi Fuel Problems
Where to find intake manifold studs
flywheel
clutch engage problem
LUK clutch
Straight pipe exhaust
Gas mileage w/o loss of power
Timing belt tension
slipping clutch!!! >=(
Compressor Surge
motor makes weird sound when giving it gas
420a Nitrous
Malfunctioning fp gauge? or not
Wheelspin?
RS-t'd or GS-T
Help Speed Sensor
cop conversion
need for speed
injector id ?
turbo intercooler intake
94 Talon missing once warm
HELP!!!!! 1992 eagle talon non turbo
93 2.0 DOHC Non-Turbo Engine - Power Drop
car won't start
A/F ratio and ignition timing
bucking & mising in midrange rpms
aem fic location
IAC testing
5 bolt flange
Cooling And Knock
head gasket and stud question
extremely high idle speed
GSX conversion to RWD??
need help with tranny
flywheel problems
trans problems
Head Service
timing belt?
Will a 1g tranny fit in a 2g?
2g to 1g head swap
Newb needs help getting a base tune
90 gst idle off idle problem
my idle keeps stalling how do i adjust this to increase idle.
car won't stop being stupid.
New Turbo pre-install
95 Eclipse...p/s leak at rack pinion
Tuning with apexi 2
Tuning apex i afc for my talon
95 Eclipse...idles erratically
Play in front passenger side axle
Swapped tranny, now I don't have any fuel pressure.
Evo 3 16g Turbo
Boost controller
Confused about the fpr
95 talon smokes rings or valves how to tell
Grinding into first and fourth
Radiator cap difference
oil leak
01 Eclipse GT idling problem
Stumble problem, also what next?
talon radiator??
timing belt help
Can I flush my AT passages in my radiator?
Need Help
short shifter?
No Overdrive?!
Melting Wastegate boost hose
need advice
automatic tranny
420a is turbo. need help
automatic transmission oil
Starting Issues
94 Eclipse 1.8...idle issues = timing belt??
First Log!
weird spinning noise 95 gs
Engine Noise 95 Eclipse
I need help on arp studs/bolts
installing front mount intercooler??
95 tsi with crank walk... :(
CEL runs rich
Slave extension
Just got my Eclipse....where do I start?
Engine Rebuild Questions...
Few questions
model specific question...
5speed swap
Blown Eclipse 98 non-turbo engine, what to do next?
The new clutch thread. ACT
Tranny fluid... synchromesh price??
car is bogging
Just got a logger, can I tune now?
1994 eclipse turbo Tranny Problem
1g awd tsi was ticking then cut off
Clutch Break In
1995 Eclipse GS HELP!
how much more air is flowing threw my haked 1g MAS?
1997 Eclipse RS
Auto to Manual
What would you recommend?
can cold air intake replace a MAS?
newbie: bought a 1990 eclipse 1.8L
fwd-awd
vss viechle speed sensor wire location
Random Idea... Would it work?
Head gasket question
F1Racing Clutch and EVOIIIGT turbo question?
Boost Question.
help need decent air map settings for my mods
auto to 5 speed
new engine question!!
6 bolt wont start help!@!!
Tranny fluid
drifting in a FWD
95 talon problems
stage 2 clutch
non turbo to turbo
2-step
my 96 eclipse gst wont start
lowering springs for the whip
Transmission acting weird. help!
Oil Drain question from filter
check engine light
gsx with a 16g at 15psi....?
1991 Eagle Talon TSI Turbo Replacement
different compression readings
New Engine!
fuel pressure regulator
new to the scene....
2.0 n/t engine
removal of intake
oil in the summer
Timing Belt Doesnt Move !
Need help on boost timing master
92 eclipse 2.0 engine problems
AOD trans not shifting correct
Pulling Timing questions
longer rods for eclipse
Performance Upgrade Tips please!
non turbo question
hard to shift
6 bolt swap help
Engine wiring harness NIGHTMARE
96 esi swap into 95 esi
95 talon tcu help
Oil blown out remdiation
Garrett GT2860RS comparable to the .....
transmission swaping
Engine Break In
turbos
Transmission flush manual
NEED HELP WITH 93 FWD N/T eagle talon
need help with fuel rail
Wanna Rebuild the Motor
Running a little rich.
Turbo question
Eclipse GSX ????'s
fuel cut?searched for 45min on here
transmission problem
retro fit
gsx tranny question
same question asked #20000000000000 and 1 times
adjustable fpr what setting?
91 talon tsi wana kno what the specs are on it?
real question
performance parts
engine swap and rebuild
E316G wastegate issues
92 laser with no reverse
Neat NT 2G Article
2.3 stroker runs rough at start
will a 2.4l nonturbo clutch fit in a 2.0l non turbo
fuel system???
"bucking" problem
14.8 1/4 mile with my mods and have a?
Engine Tick
maf mod
Transmission Trouble, Help
slipping clutch
turbo seal/gasket
cyclone intake manifold????
Is it possible to swap a..
SURFIN... and BANG!
Air/Fuel Gauge Install
1998 Eclipse slipping clutch
93 rear lsd to 98
Ebay headers & catback
Clutch kit suggestion
Vacuum Lines
Hesitation/missing problem still occurs...
oem parts help?
1995 Talon esi to turbo?
big 16g evo3 boost problem on 91 talon tsi fwd m/t
Is an A/T starter different than a M/T starter?
Question about my current set up
Mustang Throttle bodies
got a question??
Timing belt questions
Is the 4G63 a zero clearance motor?
engine
Looking for 95 Talon Rear Diferential
quick tranny question
2 types of 4G63
transmission issue..
Good read on turbos
Are these O2 sensors good?
Cam Pulley Stuck!!
4G63 Engine
4g64
disappointing drive today...
cv axles
fuel pump
timing belt stripped after 3000 km's
Thermostat
new motor, but which one?
Clutch question
Head gasket
buying new battery
Timing belt/hood lol
Black Top Cam angle Sensor ????
turbo problems
Things needed for a 6 bolt swap..
G4cs tuning and information
Head gasket
1g radiator
Tokico springs!
Installing Tensioner, How hard is it?
tranny fluid
Roll cages
