Old 04-23-2003, 02:29 AM
Deejay27's Avatar
Deejay27 Deejay27 is offline
Question Alclad II over Tamiya Primer and Tamiya Synthetic Laquer?
I was wondering if it would be safe to apply Alclad II paints over Tamiya primers and their canned spray paints or would I have to use "true" laquer based paints as a base. Thanks.
Jimmy
Current Project
"Tamiya 1/24th scale Enzo"
Completed Projects
"1/12th scale Renault FW14B"
"1/24th scale McLaren MP4/7"
Old 04-23-2003, 05:10 AM
Decs0105's Avatar
Decs0105 Decs0105 is offline
Registered User
for aluminium high polished and chrom you need a enamel base (gloss black !!!!!!) !!!!!! if not alclad II can damage the plastic !!! for all the other alclad II paints you must use acryl primer !!!
Old 04-23-2003, 06:09 AM
daggerlee's Avatar
It's definitely safe to apply Alclad over Tamiya primer or synthetic lacquers, note like TheSaint said you need to apply Alclad Chrome over a glossy black enamel surface, and Alclad Polished Aluminum over a glossy black acrylic surface.
Dan
Old 04-23-2003, 06:19 AM
Decs0105's Avatar
Registered User
Quote from Alclad2.com
Apply one of these primers before using Regular ALCLAD:
Tamiya Plastic Primers-white or grey
Auto Primer-white or grey
Future/Klear -floor sealer/polish
Plastic primers and auto primers should be lightly polished with 1000/1200 wet & dry paper to give a less absorbent glossy surface .
ALCLAD High Shine -Chrome and Polished Aluminium both require a dark glossy base. Polished Aluminium should be used over Tamiya TS-14 gloss black,or gloss black auto paint. Chrome and only chrome should be used over gloss black model enamel paint.
Old 04-23-2003, 06:54 AM
freakray freakray is offline
AF Modelrater
It actually tells you on the bottle what type of base the Alclad2 should be sprayed over, like the TS-14 and gloss black enamel, just read the instructions on the bottle when/before you buy it to see what is required.
You could also look on www.alclad2.com like was mentioned above, they give instructions and tips on their site.
Ray
AF User Guidelines
Old 04-23-2003, 08:25 AM
Veyron's Avatar
Veyron Veyron is offline
Smile
I sprayed it over TS14 on my exhaust tips before the TS14 dried and it worked great!
Old 04-23-2003, 09:29 AM
Deejay27's Avatar
Thanks for the info everyone !
Jimmy
Current Project
Completed Projects
Old 04-23-2003, 09:33 AM
SupercarFreak's Avatar
SupercarFreak SupercarFreak is offline
I ordered a bottle of their chrome, what gloss black enamel do you guys recommend? I only have acrylic: tamiya's semi-gloss black
Old 04-23-2003, 09:36 AM
AF Modelrater
It won't work over acryllics....
Alclad recommend using Testors gloss black enamel, which is what I used and it works great.
AF User Guidelines
Old 04-23-2003, 09:37 AM
many thanks ray!!!
Old 04-23-2003, 11:59 AM
daggerlee's Avatar
Oh and just a note, on their newer bottles they tell you to use "Alclad Primer" and "Alclad Black", disregard this you can just use the above stated primers and black
Dan
Old 04-23-2003, 05:59 PM
hirofkd's Avatar
hirofkd hirofkd is offline
I used Alclad over Tamiya Spray, and it was safe to use. Tamiya spray is lacquer based acrylic. It should be alright over Mr. Color and Mr. Spray, also.
Hiroaki Fukuda
Testors primer and Tamiya paint, bad result? Vyacheslav Car Modeling 10 11-15-2006 03:55 AM
Tamiya Primer and Colour Combination Jiminee64 Car Modeling 1 01-18-2004 09:36 PM
Tamiya TS-17 over white primer ]as]e Car Modeling 7 01-01-2004 06:59 AM
automotive lacquer over tamiya primer??? superpoov Car Modeling 5 10-13-2003 09:44 AM
Duplicolor automotive primer and tamiya spray paint Daryl Car Modeling 4 07-01-2002 10:02 AM
