Old 07-01-2002, 06:44 AM
Daryl's Avatar
Daryl Daryl is offline
Duplicolor automotive primer and tamiya spray paint
I'm having problems with this combination as the paint always seems to dry half-matte. I've given the spoiler for my MR2 three coats of paint but it never dries shiny. The surface looks porous.
It's a scratchbuilt GT wing made of evergreen sheets and given two coats of duplicolor primer. Any diagnoses?
Left is right. Right is wrong.
Old 07-01-2002, 07:15 AM
daggerlee's Avatar
How smooth is the surface you were painting on? Puttied up styrene sheet sounds pretty rough to me, make sure you sand it smooth, preferably up to 1500 or 2000 grit.
Dan
Old 07-01-2002, 08:11 AM
Wishmaster's Avatar
Wishmaster Wishmaster is offline
***** Lurker
It sounds the same as my first car with duplicolor. It looks like an orange peel layer.. Probably you read the instructions and followed them.. That's were the problem sits, because at a spray distance of 25 cm // 10 inches the paint is already drying and comes partial dry on the car. So you have to spray at a shorter distance, like 10 cm // 4 inches but you have to go much faster to reduce the chance of runners. This is what I learned at IPMS last week from HRmodeler's second man Rinus.. hope that this helps
Old 07-01-2002, 09:55 AM
Daryl's Avatar
daggerlee: the surface was pretty smooth. i primed and sanded it
wishmaster: so i spray the primer from much closer up?
Old 07-01-2002, 10:02 AM
Wishmaster's Avatar
***** Lurker
Yes and try to get some Duplicolor paint.. works better with eachother, Two different brands of paint//primer don't like to get mixed.. and why using expensive tamiya spray paint when you already use cheaper//better duplicolor primer..? Then use duplicolor also as paint.. enough choice and don't forget that some need clear finish.. so get that one also from Duplicolor.. works fine here.
Should I use primer under Tamiya spray paints? lotus123 Car Modeling 3 02-28-2009 10:16 AM
Duplicolor clear reacting to Tamiya spray? speedphreak Car Modeling 1 10-14-2005 12:05 PM
Automotive primer -> Tamiya Paint -> Automotive Clear DJPaul Car Modeling 5 03-08-2005 08:49 AM
Ok to use Testors primer w/ Tamiya spray paint asaenz Car Modeling 20 04-29-2004 09:00 PM
dupicolor automotive spray and tamiya spray Thing-A-Majig Car Modeling 4 06-30-2002 02:56 AM
