Old 04-17-2003, 01:49 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
cam gear bolts
ok so i got this ls motor but theres no cam gear bolts on the motor. so im wondering if my stock sohc cam bolt will fit on the ls motor ?
Team Lonely Drivers
Old 04-17-2003, 12:11 PM
Mean_B16's Avatar
Mean_B16 Mean_B16 is offline
Even if it does(which i do not think it does) you will need 1 more, why not just order them from Acura or Honda. They are CHEAP$$
Old 04-17-2003, 04:21 PM
i would just order it from honda but they aint got it in stock so it will take a week to get here so my car will be down another week, and i wanted to get my car runnin, but if i can use the sohc cam bolt then wont need to wait the week
Team Lonely Drivers
Old 04-19-2003, 04:53 PM
luti luti is offline
Send a message via AIM to luti
Easiest way to know if it works is if the threads match. Try putting it in, if it doesn't go don't force it, otherwise you should be set.
T3/T04E turbocharged ricer.
Stupid Cam Gear Bolts 95GSTRaCeR Off-Topic 5 05-14-2004 10:42 AM
is A6 cam-gear & Z6 cam-gear the same?? QuikShifter '88 - '91 Civic | CRX | Wagon | Shuttlee 8 04-12-2004 06:19 PM
cam gear bolts and update on ls swap civickiller '88 - '91 Civic | CRX | Wagon | Shuttlee 4 04-15-2003 10:44 AM
cams & cam gear installation $$$??? KEiTHo Integra 0 02-26-2002 07:22 PM
