Old 04-11-2004, 11:32 PM
QuikShifter's Avatar
QuikShifter QuikShifter is offline
is A6 cam-gear & Z6 cam-gear the same??
will an A6 cam gear work on a Z6 head?
Old 04-12-2004, 12:44 AM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: is A6 cam-gear & Z6 cam-gear the same??
D series cam gears are the same. and all b series are the same. matter of fact, b and h series are the same.
may even be that all DOHC are the same, and all SOHC are the same. not sure about the SOHC, havent checked the d series against an f series
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 04-12-2004, 07:24 AM
thanks incucivic! i also figured they should be the same but someone had told me that the d-series vtec cam-gears are different from the non-vtec.
Old 04-12-2004, 07:48 AM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
The DOHC ZC is different then the b series DOHC and H series DOHC
KoRnSaQ
Old 04-12-2004, 08:26 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
zc and b series cam gears are different..but only in regards to width...if you're putting cam gears on your zc, you'd use b series gears and get them milled down a bit.. but 88-89 teg cam gears do not fit the zc...like you'd think..
SOLD!
Old 04-12-2004, 01:29 PM
EF You's Avatar
EF Life Giver
yeah, i wasnt too sure about the ZC, but then again, it is an oddball engine
Old 04-12-2004, 05:23 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
yea, i wish there were more choices out there for zc cams. Im looking for a set right now and dont know what to get. Its all so expensive
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 04-12-2004, 06:03 PM
marked001's Avatar
Moderadur
I had a set of Web regrinds for my zc and an EL Prototypes matched ecu... never got to put them in though
SOLD!
Old 04-12-2004, 06:19 PM
probly sold it all didnt you... How much did the regrinds cost you though?
ZC stuff
Is the box chevy 2dr & 4dr roof the same? deesandvees Caprice 3 05-01-2008 05:33 PM
With 2 89' SC Mr2's (T-Top & Hardtop) with the same top of the line roll cage...... Mr2Untouchable MR2/MR-S 0 09-15-2004 12:27 PM
Top Gear & Fifth Gear download link Swoxy COMPLETELY off-topic 0 05-26-2004 08:54 PM
exhaust & intake cams the same? lodownlv 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 2 02-15-2004 08:22 AM
cams & cam gear installation $$$??? KEiTHo Integra 0 02-26-2002 07:22 PM
