Old 05-13-2004, 08:46 PM
95GSTRaCeR 95GSTRaCeR is offline
Stupid Cam Gear Bolts
sorry bout the all caps, this is getting really frustrating..... anyone know a good way to get the cam gears off, they are torqued down so damn much...are they regular threads or reversed threads?...thanks in advance
Old 05-13-2004, 09:24 PM
Talon007's Avatar
Talon007 Talon007 is offline
Send a message via MSN to Talon007
Re: Stupid Cam Gear Bolts
Regular thread.
Chris Clark
www.Talon007.com
1990 Eagle Talon TSi AWD - In Progress
1993 Eagle Talon TSi AWD - Parts Car
1990 Eagle Talon ESi - Sold
1-800-VFAQ - Bookmark it, read it, use it
Old 05-13-2004, 09:43 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
take and stick a screw driver between the gears in the middle and take a big breaker bar and bust them loose!... yes they are regular thread, so when you do the one closest to you put the screw driver in between and under them... when you do the far back one put the screw driver in between and on top of the gears so it wont allow them to move!
Old 05-14-2004, 10:32 AM
kjewer1 kjewer1 is offline
AF - Advisor
Its possible to break the cam sensor on 95-96 cars though. So if one would rather not do it that way, simply remove the valve cover (probably off anyway) and put a wrench on the cam. There is a "nut" cast into the cam for this very purpose. I believe on my HKS cams its 22 mm, stock may be larger. And adjustable works fine. Its not uncommon to need two people to do this. Put the stronger guy on the cam wrench, you dont want it turning and damaging anything.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-14-2004, 10:39 AM
EclipseRST's Avatar
Banned
oh yea i forgot about that! good point! but i meant stick the screwdriver in the teeth of the cam gear so you dont reck the cam sensor... but your way is better definately!!
Old 05-14-2004, 10:42 AM
AF - Advisor
I would be nervous about nicking the teeth, which would in turn nick the belt. Now that you mention this, the dealerships use a tool that is shaped just right to fit in between the cam gears, I believe it intended purpose is to hold the gears in alignment when you to a tbelt job. But I assume it would do an equally sufficient job of holding the gears while you crack the bolts loose. I may have to borrow one from my brother and try it.
Kevin Jewer
