Old 04-14-2003, 04:50 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
cam gear bolts and update on ls swap
ok so idk if any of u guys know im in the process of doing my ls swap, and i only can work on it on the weekends because i do go to college. ok well so for my swap, ive taken out my stock motor, and im done converting my engine bay harness for hte mpfi, i just gotta plug the 4 wires into my ecu harness and bam wiring is done. umm so my ls is almost ready to drop in, i just gotta like change the motor oil, and put the timing belt on and the motor is ready to drop in, which leads me to my other problem.
ok so i take off my crank pulley to replace the timing belt, and the crnak pulley comes off easy, so i go to put the cam gears on since the owner had adjustable before and sold them to someone else but he gave me the stock ones, anyways so i go to put the cam gears on and i look and i see no cam gear bolts, , so i call up the owner and i tell him wheres the cam bolts, he says he left it on the engine when he towed it to his friends house so his friend could take out the motor, so i called up his friend and he says he says he doesnt have it either, so now both of them claim not to have touched it, so now i fucked cause i dont have cam bolts. ok had to vent cause i pissed because now i no more cam bolts. what u guys think
Team Lonely Drivers
Old 04-14-2003, 10:15 AM
redmanjd redmanjd is offline
i have an extra if you cant get one
95 b18b
new crank, eagle rods, je 10.5 : 1 pistons, 8lb flywheel, stage 3 act clutch, billet aluminium and urathane mounts, balanced rotating mass, 14.3 @ 93mph
New additions, teo4h turbo, ssautochrome turbo manifold, custom piping, turboxs bov, dsm 450cc injectors, greddy e-manage fuel controller 13.07 @ 107 untuned
Old 04-14-2003, 02:44 PM
does anyone know if the d sohc cam bolts can be used on the ls ?
Team Lonely Drivers
Old 04-15-2003, 04:39 AM
i am not sure but it might honda only uses a few select bolt sizes. give it a try.
95 b18b
Old 04-15-2003, 10:44 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Just go to the honda dealer or acura and see how much it cost.
1975 Caprice rear end gear/rear end swap? Topless75 Caprice 3 03-10-2010 12:29 PM
Stupid Cam Gear Bolts 95GSTRaCeR Off-Topic 5 05-14-2004 10:42 AM
Torque settings on Head bolts and cam bolts viclaster Engineering/ Technical 3 05-01-2003 01:01 PM
cam gear bolts civickiller Engineering/ Technical 3 04-19-2003 04:53 PM
cam shaft and cam gears in b16a GENONCARL Engineering/ Technical 1 03-28-2003 11:36 AM
