Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 10-28-2001, 02:47 AM
AznVirus's Avatar
AznVirus AznVirus is offline
Send a message via AIM to AznVirus
Glasspack Resonator
what is the glasspack resonator exactly?
1.6 - The Underdog
GA16DE-T Club!
Old 10-28-2001, 09:24 AM
G-Forces's Avatar
G-Forces G-Forces is offline
Banned
It's a straight through resonated pipe that pack fiberglass strands around the main pipe to muffle sound/pressure waves. Stay away from the if they contain a louvered core. Meanig if you look down the pipe and see little 'vents' stickin up don't get it. Or get it sized so that, taking the louvers into account, the inner diameter is still the same size. Meaning if you're building a 2.25" exhaust you might need a 2.5" or even a 2.75" resonator.
Old 10-28-2001, 12:30 PM
AznVirus's Avatar
will it increase the sound a bit? i assume that it gives a little performance due to better straight airflow. the resonator goes before the pipe that leads to the exhaust right?
1.6 - The Underdog
GA16DE-T Club!
Old 10-28-2001, 01:04 PM
G-Forces's Avatar
Banned
No a resonator is supposed to decrease sound. If you want a louder exhaust note don't put a resonator on. A resonator typically goes on the straight section right after the cat.
Old 10-29-2001, 11:32 PM
TIZAO TIZAO is offline
Send a message via AIM to TIZAO
If you want the car to sound loud, cut off the muffler, and then put on the glasspack, then add a nice tip to it. I have my car straight piped with no glasspack, it sounds great untill you go full throtle too about 4000 then it baffles really bad, with a glass pack it wont baffle. I got mine straight piped with a good tip for 120, glass packs are only like 20-30 dollars, I will add one on when I have the chance. Dont just straight pipe! Add a pack. You will like the sound if you want loud.:alien: :licker: :smoka:
Tao Le
[email protected]
asianata
Tao"TIZAO"Le
PRIMERACING20
Old 10-30-2001, 07:30 AM
NismoPC's Avatar
NismoPC NismoPC is offline
You must not like to hear yourself think while driving. That set up would wake up the entire state of Washington.
AznVirus,
When and if you decide to get a cat-back custom exhaust, it is highly recommended by many (read Mike Kojima's article in SCC on custom exhausts. I believe it was the October issue ???) to install a glasspack after the cat. Then the piping will lead to your aftermarket muffler and exit through the tip of your choice.
The glasspack will drastically cut back on in-cabin resonance and will give the exhaust a more milder deeper tone.
Most aftermarket bolt-on catbacks (Greddy, etc) have an actual resonator already built in to the piping. No need to add one yourself.
Now, if you want to have a bumble bee exhaust "bwabwabwa...buzzzzzbuzzzbuzzbuz!!", be my guest and follow TIZAO's advice.
Brandon
'96 G20 - modified
Old 10-30-2001, 09:21 AM
AznVirus's Avatar
nonono, i didnt want a bumble bee exhaust i just wanted to know if i will get horsepower out of it and NOT increase sound. i dont want my car to sound like a honda. i just wanted to know if it was after the cat, or right before the tip.
1.6 - The Underdog
GA16DE-T Club!
Old 10-30-2001, 10:32 AM
NismoPC's Avatar
No HP gains, just a sound mind.
By the way, see my sig. It's a pearl titanium white just like yours, but a '96. Pretty nifty color and I do not see much of them here in Ohio.
Brandon
'96 G20 - modified
Old 10-30-2001, 01:51 PM
AznVirus's Avatar
dont have my car anymore thought everyone knew i crashed it how much do glasspack resonators cost?
1.6 - The Underdog
GA16DE-T Club!
Old 10-30-2001, 02:14 PM
NismoPC's Avatar
The THRUSH glasspack cost $15. I think the part # is 21205. It is 25" long glasspack with a 20" canister. 2.25" I.D. in/out and the center core is 2" I.D.
Most of them run between $15-$30 depending on quality and where you purchase them.
NAPA wanted $29.99 for the THRUSH. I picked the same one up at JEG's Performance here in Ohio for $14.99. JEG's has a website for online purchasing as well.
Brandon
'96 G20 - modified
Old 10-30-2001, 08:24 PM
Ok ok ok so everyone is hating on my idea. Actually with the gp on it makes it a lot quieter than just straight piping, I made that mistake already. Its not too, bad. If you want performance while making it quiet, put a high flow cat on and then a glass pack. I have high flow cats for under $100! Let me know if you are interested. :alien: :licker: :smoka:
Tao Le
[email protected]
asianata
Tao"TIZAO"Le
PRIMERACING20
Resonator or no Resonator Franky-5-Fingaz Thunderbird 2 08-28-2004 09:21 PM
Glasspack on 1987 Grand Marquis jjguitar Grand Marquis 10 03-22-2004 09:05 PM
Cherrybomb/glasspack resonator to quiet exhaust? RedRacerCivic '88 - '91 Civic | CRX | Wagon | Shuttlee 7 11-06-2002 03:25 AM
Glasspack help jjguitar Engineering/ Technical 1 03-12-2002 10:39 PM
Glasspack as a resonator ??? NismoPC Engine 5 08-31-2001 09:52 PM
