Old 04-10-2003, 05:18 AM
cyberrexer's Avatar
cyberrexer cyberrexer is offline
Send a message via AIM to cyberrexer
Larger throttle body & intake manifold
Theoretically what would be the gains from a 70mm throttle body along with a port and polished intake manifold which has been port matched to the 70mm throttle body. I take it the ECU would need to be remapped, but would I need larger injectors? If so what would be my options/price.
Any problems I could possibly encounter? Also would this put me in good stead for a possible turbo application in the future.
Any advise appreciated.
Thanks!
1991 CRX siR
1991 CR-X Si
1993 UK 2.2 4WS - FOR SALE
2005 Lexus IS200 - SOLD
1990 MX-5
Old 04-10-2003, 09:09 AM
cyberrexer's Avatar
Anyone?
1991 CRX siR
1991 CR-X Si
1990 MX-5
Old 04-10-2003, 10:03 AM
91civicDXdude's Avatar
in the best case scenario, i'd say you'll get about 10hp from the throttle body
Old 04-10-2003, 12:44 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Thats too big. U'll lose torque. I'd go with 64-66 mm.
Old 04-10-2003, 05:06 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
your car will learn and adjust to the new amount of air going into the engine
Team Lonely Drivers
Old 04-10-2003, 08:08 PM
kris's Avatar
kris kris is offline
Off playing with fire.
It will do more harm then good, if other stuff is not done first. What have you done to the head? Vavle job? P&P on intake and exaust, header, exhaust?
If you dont work on those things first, you wont gain anything.
Old 04-11-2003, 04:15 AM
cyberrexer's Avatar
Thanks for the replies, so far I have a HKS header, induction, custom exhaust and Hondata chip. I’ve been told the car will adjust to a certain point but not that much. As I have a Hondata chip re-mapping isn’t a problem, but would I need larger injectors?
The throttle body comes with a port and polished intake manifold to match. Didn’t realise about the loss in torque though.
1991 CRX siR
1991 CR-X Si
1990 MX-5
Old 04-11-2003, 02:14 PM
SiZ's Avatar
SiZ SiZ is offline
How the hell are you going to lose torque?! Do people even know how HP is made?! Geeze.
IM and TB would be a good next step, then it would probably be a good idea to get a cam.. You shouldn't need bigger injectors, your car really shouldn't be demanding that much more fuel just from basic bolt ons.
"The nympho of info, I'm fuckin' what ya heard"
Old 04-11-2003, 02:31 PM
cyberrexer's Avatar
I've been told that the injectors run almost flat out at peak power on a stock SiR, there isn't much headroom (and winding the fuel pressure up is a bit of a bodge).
1991 CRX siR
1991 CR-X Si
1990 MX-5
Old 04-12-2003, 02:48 AM
mellowboy's Avatar
Well my boy bought BBK tb for his gsr. He lost tq! 113 lbs of tq when he dyno'ed I'll see if he has dyno sheets for his ride.
Old 04-12-2003, 03:57 AM
BigBearWest's Avatar
BigBearWest BigBearWest is offline
WWW.CalgarysFinest.COM
Send a message via ICQ to BigBearWest Send a message via AIM to BigBearWest Send a message via MSN to BigBearWest
Any one know where i could pick up a 70mm TB for cheap
My Name is Roberto AKA. Berto
Old 04-12-2003, 08:27 AM
see waht more air does is it keeps the torque up at higher rpm instead of going down. so with the torque leveling off, and not dropping, u get an incease in hp up high
Team Lonely Drivers
Replace Intake Manifold Gasket Stammtra Cougar 4 07-20-2010 01:13 AM
'00 cavalier, odd noise and oil in air intake/throttle body warik Cavalier Problem Diagnosis 4 04-23-2009 07:11 PM
Finally, HO Throttle body and Intake Manifold inarifennec Performance 6 05-21-2005 09:00 PM
throttle body and intake manifold? Vroinshk06 Integra 8 04-05-2005 10:16 PM
Throttle Bodies and Intake Manifolds??? DSMNerd6889 Off-Topic 6 02-24-2005 04:08 PM
