Old 02-21-2005, 08:47 PM
DSMNerd6889 DSMNerd6889 is offline
Throttle Bodies and Intake Manifolds???
Here's the deal, I am wondering what stock intakes are interchangable and what throttle bodies wil interchange with what intakes. I am only talking about bolting up, we are disregarding any sensors. Thanks
1990 GSX
PTE SC6152e, tubular manifold, FIC 650's, wiseco/eagle internals, dsmlink, TRE tranny, Apexi dp and cat-back, Apexi EGT and Boost Gauges and Turbo Timer, Megan Racing FPR, Walboro 255 Pump and much more to come.
Old 02-21-2005, 09:01 PM
mitsu_eclipse95gst's Avatar
mitsu_eclipse95gst mitsu_eclipse95gst is offline
Re: Throttle Bodies and Intake Manifolds???
any 89-94 manifold will work they are all the same i think its 92.5 up TB 89 will work if you are capping your lines off **i think** that is right i have 89 so i know that works
1990 Mitsubishi Eclipse GSX
1995 Mitsubishi Eclipse GS-T (SOLD)
2002 VW Jetta 1.8T
Old 02-21-2005, 11:14 PM
TsiTalon9587 TsiTalon9587 is offline
Send a message via AIM to TsiTalon9587
Actually, I think I remember Kevin trying to bolt a 1g manifold onto a 2g head, and wasn't able to do it without leaks. I recently was holding up two mani gaskets together, and they seems quite different.
Aaron B.
95 TSi DSMlink'ed Evo3'ed 6 bolt
52.7 1/4 second try
11.0 1/16th 2nd in league.
22.3 1/8th Ties league record.
6.6 55 meters
Old 02-21-2005, 11:37 PM
http://users.frii.com/maphill/coil.html go there other people besides me have done this
2002 VW Jetta 1.8T
Old 02-22-2005, 03:29 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Re: Throttle Bodies and Intake Manifolds???
Other way around, you can't put a 2g manifold on a 1g head. It physically bolts up, but the ports on the 1g head are larger than the entire flange on the 2g manifold, so you get some massive leaks A friend of mine just learned this the hard way too, car barely runs.
Putting a 1g manifold on a 2g head is retarded, if you dont port match the head. Put a 1g gasket on the 2g head, and you can see the ridiculous step down in size. Not good for airflow
Any DSM TB will bolt onto any DSM manifold (assuming turbo in the case of 2Gs, 1g 2.0 NT works, not sure about 1.8). But again, putting a 60mm 1g TB on a 2m manifold doesnt make sense if you dont take that 52mm hole out to 60. 91-94 and 95-99 are interchangeable, but a 2g needs the 2g TPS. ISC connectors are the same. The 90s are different both in the ISC and TPS, and in the vac setup, don't waste your time with them.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 02-22-2005, 12:12 PM
yea i didnt mention that. IF you put a 1G on 2G "PORT MATCH"
2002 VW Jetta 1.8T
Old 02-24-2005, 04:08 PM
dsmodder dsmodder is offline
Send a message via AIM to dsmodder
everything you need to know... http://www.roadraceengineering.com/1...waptechtip.htm
