Old 04-05-2003, 06:58 AM
Camber's Avatar
Camber Camber is offline
Send a message via AIM to Camber Send a message via Yahoo to Camber
Question Painting with Pearl White
Ok, let me get this straight. Is this the proper way to get a successful shiny pearl white paint job? I dont think I did it right on my 300zx.
1. Primer
2. TS Pearl
3. Clearcoat
4. Sand then Compound and Wax
Is there anything other steps I forgot?
Old 04-05-2003, 07:05 AM
Veyron's Avatar
Veyron Veyron is offline
Smile
Your steps look perfect, what happened?
Old 04-05-2003, 07:12 AM
Vric's Avatar
Vric Vric is offline
Compond + clear coat = flat color for me..
Old 04-05-2003, 07:34 AM
TheSyndicate's Avatar
TheSyndicate TheSyndicate is offline
I've never used TS pearl, but I remember people saying it isn't a basecoat type paint, but rather a transparent sparkle paint. Perhaps you should have applied it over gloss white?
Old 04-05-2003, 07:35 AM
Camber's Avatar
Well with my 300zx, I never sanded it b4 compounding the clear coat so it was'nt as shiny as I had hoped.
Old 04-05-2003, 07:37 AM
Camber's Avatar
Yea it is transparent, I was thinking maybe I should lay down some coats of gloss white b4 pearl too. But would I have to sand and compound and wax the white b4 the pearl or can I just clear coat the pearl and white then compound. Im thinkin compounding b4 pearl and clear is a bad idea, eh?
Old 04-05-2003, 08:02 AM
Veyron's Avatar
Smile
Remember, your first step after clear coating the pearl white is to sand the clear in order to level it. The first step in polishig(leveling) is the most importatant, it's the step where orange peel is removed. From there you proceed to use higher grit sand paper than you started with, then the compund, then wax. Sounds like you skipped sanding the orange peel out of your clear and went straight to compound.
Old 04-05-2003, 08:07 AM
Camber's Avatar
Yep, I did'nt kno as much as I did now when I did it.
Old 04-05-2003, 03:18 PM
Ragnarok043's Avatar
Ragnarok043 Ragnarok043 is offline
Send a message via AIM to Ragnarok043
yes you need to spray down a white base coat first before spraying on the pearl or else you'll end up with pearl grey(assuming youre using grey primer). so you should be doing it in this order
1. prime
2. white base coat
3. pearl
4. clear coat
5. polish
6. wax
you might still have to sand and polish in between these steps if you get severe orange peel.
Old 04-05-2003, 08:32 PM
themodelkid's Avatar
themodelkid themodelkid is offline
Send a message via AIM to themodelkid
1. prime
2. white base coat
3. pearl
4. clear coat
5. polish
6. wax
Perfrect!:bandit:
themodelkid-Frank
2004 Dodge Intrepid SXT 3.5L HO
Brilliant Black Crystal Prl. Metallic
250hp, 250 lb ft tq.
1995 Dodge Intrepid 3.5L
Stone White
230 hp, 246 lb ft tq.
Supercharger in Works...
1987 Chevy S-10
Midnight Blue Prl. Metallic
300hp, 314 lb ft tq.
5.0L Baby...
Old 04-05-2003, 08:36 PM
integra818's Avatar
integra818 integra818 is offline
Send a message via AIM to integra818 Send a message via Yahoo to integra818
I had the same problem, I though the paint was'nt shiney, but I figured the paint was supposed to look like that >I think<. Just wait a while and spray clear over it if you want it to be shiny, but that paint is pretty hard to get off.
Old 04-05-2003, 10:44 PM
Camber's Avatar
My 300zx did'nt look that grey with no white base coat. I think not using a white base coat is a way to reduce orange peel on it. I mean, you are going to clear coat it all, so whats the difference?
Pearl White and Pure White TanKaBoY Car Modeling 8 11-04-2004 03:51 AM
Painting with Pearl BOOSTD Car Modeling 2 05-06-2003 06:05 AM
How to paint Pearl white? AccordTypeR Car Modeling 3 11-26-2002 08:16 PM
pearl white s2000 with white interior urban1979 Car Modeling 14 07-19-2002 03:26 PM
touch up paint for my Pearl white car and another question? lukeyc3 Cosmetics 7 03-10-2002 05:48 PM
