Old 11-03-2004, 03:16 AM
TanKaBoY's Avatar
TanKaBoY TanKaBoY is offline
Pearl White and Pure White
whats the difference?, because my Apexi D1 FD just came in, and i plan on making it the 2003 version(because he won), and i need the white that looks like his one.
so please help =)
one more thing, does any have shots of the D1 Apexi FD's interior?, because i wanted too see where the gauges are.
THANK YOU!
Completed:
Sexy Iwase Kyoko's FD3S RX-7
Apexi D1 FD3S RX-7
Old 11-03-2004, 03:43 AM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: Pearl White and Pure White
well pretty simply put, pearl white has a pearl effect to it. Pure white is just plain white.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 11-03-2004, 05:44 AM
Martbee Martbee is offline
Good resume. A pearl will reflect a good range of spectral color (pink, red, blue, green.........). A Pure White will be... white.
Old 11-03-2004, 08:11 AM
Vric's Avatar
Vric Vric is offline
also pearl white look better, but is more transparent, so you will need white primer ou pure white as under coat
Old 11-03-2004, 12:54 PM
MidMazar's Avatar
MidMazar MidMazar is offline
great now im screwed, used grey primer and already did 2 coats of pearl white, no wonder it came out grey, damnit
In Progress
Old 11-03-2004, 01:07 PM
freakray freakray is offline
AF Modelrater
You should never use a grey primer under white, or yellow, both are translucent colors which will show whatever you used underneath it.
When I spray white, I always use white primer, then flat white base coat and then top coat, it gives a more 'solid' looking color.
AF User Guidelines
Old 11-03-2004, 03:17 PM
D_LaMz's Avatar
D_LaMz D_LaMz is offline
I got some pic of the interior
Old 11-03-2004, 08:31 PM
Vric's Avatar
never use gray primer with yellow, red, orange, green or white paint. (don't use gray unless you use a dark color)
Old 11-04-2004, 03:51 AM
TanKaBoY's Avatar
ok thank you for the pictures and the colour question =D
Completed:
Apexi D1 FD3S RX-7
