Old 03-27-2003, 04:58 PM
blueturtle blueturtle is offline
Send a message via AIM to blueturtle
dual exhaust
how would one go about getting custom dual exhaust in a 90 dx hb?
b/c i wanna get that on my car any help is greatly appeciative (sp)
thanks
Old 03-27-2003, 05:00 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
Go to your local muffler shop, and they should be able to rig one up for you for cheap.
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Just go to the muffler shop and have them do it for you.
Old 03-27-2003, 05:01 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
It's your car do whatever you want, but keep in mind dual exhaust adds a lot of weight, and will totally devoid your car of backpressure which it needs to run correctly.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 03-27-2003, 05:06 PM
oh.... so are you saying if i really want dual exhasut i would need to have what the true dual exhasut has like 2 minifolds and all that shit eh.?
Old 03-27-2003, 05:13 PM
No what I'm saying is the 4 cylinder engine does not produce enough backpressure to have a need for a duel exhaust. V8s have a dual exhaust because they are huge and can pump out enough backpressure that adding a bigger exhaust won't take that much away from it. Even so some V8s don't even have dual. So I'm saying if you add dual exhaust its like saying your car can produce 5 backpressure, but you are taking away like 7 backpressure. Those aren't real measurements but you get the idea, your taking away more than you have to give basically.
Backpressure is a vacuum inside the engine and exhaust that helps the intake and exhaust valves run better, without it the engine will struggle more.
Old 03-27-2003, 05:26 PM
oh ok scratch that idea
Old 03-27-2003, 05:31 PM
One thing you can do that won't hurt your car probably is do like some Dodge Neon mufflers do. Since they have the same kind of muffler we do (the one that hangs horizontally out of the middle of the back) they have the usual exit on one side, and another one coming out of the other side, so you basically have a regular exhaust, but dual exit.
Old 03-27-2003, 05:37 PM
actually thats like what i wanted lol
just wanted the cat back to split into 2 mufflers (prefinable really loud hot sounding mufflers)
and since my cadalitic convertor is shot its a failed pos and im too cheap to replace it how much hp would i gain if i just hollowed it out and pout a straight pipe through it so inspecions thinks i have one (since in ct they only check with a mirror)
Old 03-27-2003, 05:38 PM
except i dunno what kind of muffler to get
98 2wd 4.3 dual exhaust jesse938 C/K 3 05-17-2009 12:37 PM
Dual Exhaust systems or Single Exhaust system ? Alaa 3000GT 3000GT/Stealth 17 12-25-2004 08:19 PM
Single Exhaust to Dual Exhaust on my box....Looking for advice BoxChevyUC Caprice 1 07-29-2004 11:14 PM
Dual Exhaust str8maxn Engine 10 12-20-2001 06:01 PM
Dual exhaust b-b00gie Engine 6 05-17-2001 11:23 AM
