View Poll Results: What exhaust system style you prefer?
Dual Exhaust systems 3 37.50%
Single Exhaust system 5 62.50%
Voters: 8. You may not vote on this poll
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 12-22-2004, 02:19 AM
Alaa 3000GT Alaa 3000GT is offline
Send a message via MSN to Alaa 3000GT
Wink Dual Exhaust systems or Single Exhaust system ?
Hey there
Which one do you prefer ? Dual or Single ?
Old 12-22-2004, 03:19 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Re: Dual Exhaust systems or Single Exhaust system ?
Single
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 12-22-2004, 12:23 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Originally Posted by Alaa 3000GT
Hey there
it would depend upon the application. what's the platform? the 3000GT doesn't have a true dual exhaust. tho i love the low rumble and hum of a dual exhaust with headers on an LT1 Camaro.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 12-22-2004, 12:25 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
I like the way dual looks, too bad its not a true dual on the 3S but I guess that would mean two cats and piping which would drive up the price and weight. Dosent the 300ZX have true dual?
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 12-22-2004, 03:28 PM
G35turbo G35turbo is offline
what do u guys mean by true dual? when u change to after market exahust it becomes a true dual right????
beause i want to get a custom cat-back with the quad tips.
Old 12-22-2004, 04:31 PM
GritMaster GritMaster is offline
3000gt style dual exhaust: One down pipe one Cat, whish splits into two pipes that go back to the mufflers
True dual: 2 sets of cats and pipes one from each "Bank" of cylinders.
I.E. one pipe for the front 3 cylinders, one pipe for the back 3 cylinders (usu it would be one for left, one for right, but because of the engine placement, i said F&B)
RIP Andy "Hypsi87" Filson... We'll miss ya mate
Originally Posted by nissanstreetz
For about 700 dollars you can have about 80 horespower at the wheels and about 70 torque.
Old 12-22-2004, 04:42 PM
3000Star 3000Star is offline
Send a message via AIM to 3000Star Send a message via Yahoo to 3000Star
would it be safe if i ditched the fake duals and just had one aftermarket pipe..cause it would lower the weight a good pit, and its cheaper. but does that other little shitty pipe realy make much of a difference...need imput
Old 12-22-2004, 07:19 PM
Thourun's Avatar
I think it looks great, I like total simetry on a car.
1995 3000GT VR-4
Old 12-22-2004, 08:02 PM
Nope the other pipe won't make a diffreence if you're running a single 3" pipe or even smaller possibly, it depends on the diameter of your downpipe. if it's only a 2" downpipe then a 3" catback won't really do much more than a 2" catback.
So, Nope it doesn't matter
Old 12-22-2004, 09:34 PM
How dose the True Dual work on the vr4? Is there enough room under the car to run two different 3" pipes all through the car.
Old 12-22-2004, 09:53 PM
Don't think anyone has ever put true dual on a vr-4
It's just not practical for this specific application.
Old 12-22-2004, 10:47 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
There's been a few true dual VR4's but everyone basically said it was a waste of money and just added weight.
Old 12-23-2004, 12:28 AM
lol, so its not worth the extra hp becaue of the weight???
Old 12-23-2004, 12:38 AM
You also wouldnt need 2 3" pipes, 2 2" pipes should be enough.
Old 12-23-2004, 01:29 AM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
Re: Re: Dual Exhaust systems or Single Exhaust system ?
yes, the 300zx (z32(90-96)) has true dual exhaust...
and to me, it depends on the application...on a 3000gt i would take a true dual set up with nothing but 2 huge dual-tip mufflers, on on each side. that should give that low rumble that everyone loves.
ZedEx Crew Member #4
Closed Thread
