Amp size
iight, i need sum info about amp sizes and which names are best suitable for my subs. What i have is 2 12" JL w0's in a saparted sealed box. And im lookin for sumpin fairly cheap. thnx
lightning audio is built by Rockford Fosgate at about half the cost. I stand by Rockford from previous use and I am currently using Lightning Audio. I would go with them for quality for the money. I would looks for around an 800 watt, 2 channel amp. Good luck, outta slam
an 800 watt amp for two subs that each have 125 watt power rating
i dont get it
Well, is it a 12W0-4, 12W0-8 or a 12W0-12?
I wouldn't give them more than 250W RMS, each. |
what do u mean by 4 8 or 12?? r u tlkin bout ohms? cause hers all the configs for them
Nominal Diameter: 12 inches (300 mm) Continuous Power Handling: 125 Watts Voice Coil: 1.38" diameter, 6-layer, Kapton former Available Configurations: 4 ohm or 8 ohm (Single Voice Coil) Xmax (one-way, linear): 0.34" (8.6 mm) Sealed Enclosure Range: 1.00-1.75 cu.ft. (28.3-49.5 liters) Ported Enclosure Range: 1.75-2.75 cu.ft. (49.5-78.0 liters) VRC™ Technology: YES
Yes, imperidance. They come with either 4,8, or 12 ohm coils.
go with audiobahn they are great. you camn hook your speakers in series to drop the impedance. the problem is you have to have an amp that can handle those ohms. if you power is 125 watts rms get a 300 watt amp
95 b18b new crank, eagle rods, je 10.5 : 1 pistons, 8lb flywheel, stage 3 act clutch, billet aluminium and urathane mounts, balanced rotating mass, 14.3 @ 93mph New additions, teo4h turbo, ssautochrome turbo manifold, custom piping, turboxs bov, dsm 450cc injectors, greddy e-manage fuel controller 13.07 @ 107 untuned |
what would yall recomend with 2 12" kenwood 3005's, 700w peak power 175 rms, i really dont know much about subs or amps or anything, i was trying to sell these but no one wants to buy them so i might as well use them
2002 Acura TL Type S 1991 Honda Crx Si |
Re: Amp size
. But the subs were fine. I would say a good power range on an amp for those subs would be any where from 200-400 watt, now the name brand, thats just a personal preference, I'm fond of MTX. They have great quality stuff. I also had a Jensen 300 watt amp running at 2 ohms hitting even later than it was on the Planet Audio. All of this was with one amp hooked up in a series...i think it series
Tony 91 Civic Sedan DX - Stock 287k Miles |
