Old 10-08-2003, 11:09 AM
profesguitar profesguitar is offline
Question What size amp should i use
Im going to buy two Volfenhag ZX-4712 DVX subs at 1000 watts a piece. i need to know which size amp would be best for this. i also am debating on a bandpass or other enclosure,which would be best.
Old 10-08-2003, 11:59 AM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: What size amp should i use
k, those subs can handle 500 watts a piece have each has 2 4ohm VC. You want an amp that can put out 500x2@2ohm or 1000x1@1ohm
either is pretty easy to find, I've heard good things about the Tsunami DB1100, it puts out 1100x1@1ohm which should suit your needs pretty well. The JBL BPX1100.1 also puts out 1100x1@1ohm. Either would work nicely
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
