Old 12-14-2010, 01:32 PM
Chupacabra111 Chupacabra111 is offline
AMP/Speaker wiring in cooler boom box
My first box was great. I am making another one because I wanted a subwoofer. I am not an expert at AMP and Speaker wiring so I need help if you are able.
Equipment:
Bazooka BT6028DVC 6½” tube:
· dual 8-ohm voice coils
· 5-way binding post wire terminals
· power handling: 12-300 watts RMS (150 watts per voice coil)
· frequency response: 39-1,500 Hz
· sensitivity: 100 dB
Rockford Fosgate FRP400-4 Punch 400:
· 4-channel car amplifier
· 50 watts RMS x 4 at 4 ohms (100 watts RMS x 4 at 2 ohms)
· 200 watts RMS x 2 bridged output at 4 ohms (4-ohm stable in bridged mode)
· CEA-2006 compliant
· Dynamic Thermal Management cooling system
· variable high- and low-pass filters (50-500 Hz, 12 dB/octave)
· variable bass/treble boost (0-18 dB at 45 Hz, 0-12 dB at 12,000 Hz)
· optional wired remote bass/treble boost
· Class-AB amplifier design
· MOSFET power and output stages
· 4-gauge power and ground leads and an 80-amp fuse recommended — wiring and hardware not included with amplifier
I have a Pioneer head unit with 2 channel output, so I'll be using the amp in 2 channel mode.
I haven't purchased speakers yet. I'd like a recommendation with cost in mind (I have already spent too much on this...)
My guess is to put the amp on low pass for the tube, and high pass for the other (I want 4) speakers. What is the best way to go about this?
Old 12-14-2010, 04:26 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: AMP/Speaker wiring in cooler boom box
you can just connect both pairs of speakers to the front channels and bridge the rear channels and a put a sub on it. There should be a diagram in the maqnual for this setup.
Old 12-14-2010, 09:14 PM
I was very much hoping for an easy answer like that. Thanks! Any recommendation on what size speakers to get? Watts? Also, should I run the 4 speakers serial or parallel?
Old 12-15-2010, 09:53 PM
Audio Guy
run them parallel, if you run them series each speaker won't be getting much power.. Any set of 6 1/2 or 6X9 should do, power wise. Just remember you will not be able to fade the volume front/rear with this arrangement.
Old 12-16-2010, 09:22 AM
Thanks!
Old 12-20-2010, 02:55 PM
OK, ran into something else: The tube is dual coil. Should I wire it to 2 of the 4 channels, one on each coil, or should I wire them in parallel to a bridged 3 and 4?
(Keeping in mind the specs say it's dual 8ohm voice coils)
Then, I'll have the 4 other speakers on the first 2 channels at high pass. In parallel as you said earlier. Looking at the power of the amp, what is recommended for speakers watt and ohm wise?
Old 12-20-2010, 05:29 PM
Audio Guy
you just have one tube with one sub in it ? If so, wire the 2 voice coils in parallel and then bridge channel 3 & 4 on the amp to run it
Speaker wire replacement mikeburrit01 1st Gen 95-99 0 09-27-2010 09:31 PM
12 inch Memphis c class sub, box, amp, and wires for sale! **CHEAP!** 1020hp dodge Cars/Parts for Sale/Exchange 0 10-17-2006 08:56 PM
Selling 2 - 12.1 SVC Infinity Perfects in sealed box with amp and wires!!!!!!!!! Kudweiser Car Audio 1 07-19-2005 07:45 AM
amp and speaker wiring soundwavesdj4u Car Audio 1 06-12-2004 10:59 PM
Wiring AMP/Speakers Question hobbesateclavin Car Audio 12 06-03-2004 02:52 PM
Tags
amp , chest , ice , speakers , wiring
