Old 03-19-2003, 05:09 PM
ev0lution7 ev0lution7 is offline
Send a message via ICQ to ev0lution7 Send a message via AIM to ev0lution7 Send a message via Yahoo to ev0lution7
Crank Pully HELP!
ok my water pump is TOAST its pouring water out like its gotta piss like a race horse anyways i need to get the crank pully off and its not comming off i've tried wrenches in the pully to the block to hold it still i've tried jamming a prybar in the flywheel teath but this thing wont budge AT ALL i've broken lots of tools JUST on this trying to get it off i need some suggestions fast
Crxce- theoretically if u laid a starter on a table and hooked up the wires would it run???
BLU CIVIC- no...it doesn't have any legs
Old 03-19-2003, 05:17 PM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
If you have access to a impact gun that might work.
If you dont, I'd suggest getting the right tool for the job. I can't remember the name of the tool that get's that bolt off, but if you goto a automotive store, tell them your situation and they will hook you up.
||JEFF| |
Candy Orange 1990 Honda Civic H/B
Old 03-19-2003, 05:34 PM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
I would take it to a shop with an impact and have them zip it off or.....get a breaker bar and put a pipe on the end of it and have a friend hold down the brakes or wedge something in the teeth of the flywheel.
Old 03-20-2003, 04:30 AM
well you see i've tried the flywheel thing....... tried the brake and 1st gear thing i've tried my impact gun (its just a crasftman cheepy one like a 90lb gun) nothing is working.... maybe if i drop some cord in the #1 cycl BTDC?? then crank it to TDC maybe that would lock it up?? any other suggestions??
Old 03-20-2003, 05:09 AM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
Huh? :huh: - what does that mean?
I hate D-series crank pulley bolts
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
sciamop sciamop is offline
The crank pulley bolt calls for 150+ lbs of torque (might be even tighter after years/thousands of miles). Here's what I do I on the Supra:
-- Since the engine rotates clockwise (on the Supra; check honda's rotation 1st), I put the breaker bar with extension (aka good strong pipe) on the crank bolt to the right ( illustration: *\ ) with the bar resting FIRMLY on the ground (preferably cement/concrete NOT muddy dirt). You do not want your breaker bar moving AT ALL.
-- Clear the area of civilians.
-- Make sure car is in neutral and click the starter over for a split second. This should break the bolt loose. If not, repeat procedure.
Warning: if your starter or battery is weak, this won't work. I'd resort to a breaker bar with l o n g pipe and a screwdriver handle wedged in the flywheel... You might also need a friend if you weigh less than 150lbs...
Todd
91 Civic SI
89 Supra Turbo
Old 03-20-2003, 05:11 AM
sastanley's Avatar
AF Premium User
Unfortunately dude..that is half the issue...D-series motors rotate counter-clockwise...the bolts only get tighter as we drive the car - I think that is why they are so difficult to get apart
-Shawn
'91 Civic DX sedan
Old 03-20-2003, 06:14 AM
So put the breaker bar under the frame (make sure it's not near the rack, etc) on the right side of the engine... IIRC, the x-member would be a perfect blocking point.
Todd
Old 03-20-2003, 06:49 AM
that wont work
no matter what our engines rotate counter clockwise so it would end up tighten the bolt any other suggestions how about that tool?? for getting off pully bolts??
Old 03-20-2003, 07:50 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
there are special tools that are made to remove the crank pully bolt.
here it is from sears
http://www.sears.com/sr/product/summ...id=00947626000
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 03-20-2003, 08:02 AM
that is for getting it off the crank once the bolt is off not to remove the bolt
Old 03-20-2003, 10:10 AM
You're right wow, that sucks. Big pipe time.
Old 03-21-2003, 12:02 AM
ok i've tried all that and nothing is working i'm running out of time and options i got a bigger impact gun and still it wont come off its a 350+tq gun so i know its pretty good but my compressor runs out of air kinda fast but still i've gotten off the same kinda bolts with the same compressor/ gun combo so i just dont know i'm really tired of mess's with the stupid pully any more suggestions?? maybe buy that special tool???
Old 03-21-2003, 06:31 AM
Have you tried harsh language?
-- wedge a screwdriver handle in the flywheel
-- Round up 4 or 5 friends (feed them beforehand)
-- have them all hang (feet off ground!!) on a 8 foot long pipe w/ breaker bar
If it STILL doesn't come off, take it to a garage.
Todd
Old 03-21-2003, 06:46 AM
crxlvr's Avatar
your prolly making it tigther this whole time, try reversing the gun and spinning it off.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
96 accord crank pully HELP!!! gpn50 Accord/TSX/Accord Hybrid 7 06-11-2008 10:41 AM
Crank pully and Crank gear 97 2.5....Help toverbo Avenger 2 10-04-2007 09:05 AM
Help! How do i get the crank pully off? blueburbboober 626/Capella/Capella Wagon 2 01-21-2006 02:43 AM
Help Fast Crank Pully Removal!!! Please Help 5gcivic Neon | Plymouth Neon 6 04-01-2005 04:16 PM
Crank Pully Removal help Please Sparsky '88 - '91 Civic | CRX | Wagon | Shuttlee 32 12-23-2004 11:49 AM
