Go Back   Automotive Forums Car Chat > Dodge > Avenger
Old 10-03-2007, 11:24 AM
toverbo toverbo is offline
Crank pully and Crank gear 97 2.5....Help
When I try to pull off the crank pully it moves away from the engine and so does the crank gear. They are as one.
Any suggestions on how to seperate the two? I am in the process of changing the water pump and timing belt, idlers and tensioners - poss any leaky seals. I am stalled.
Help.
Old 10-03-2007, 05:05 PM
new2mitsu new2mitsu is offline
Re: Crank pully and Crank gear 97 2.5....Help
what have you tried thus far?
'93 3000gt VR-4
170k, 27k on JDM motor
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Mods to come: Upgraded Fuel System and 75 shot of Nitrous, Full Exhaust and hopefully 15Gs
Audio
Sony Deck
Eclipse 6x8 2 ways in the back
Clarion Kevlar cone Component System in the front
2 Alpine Type S 10 inch DVc Subs
1 Audiobahn 10 inch DVC D Jones Series
One 800 Watt Jensen amp
and a soundstream 300 watt 4 ch to the speakers
And still under 4000 lbs w/ me in the car
Old 10-04-2007, 10:05 AM
I've tried to seperate with a thin putty knife, rubber mallet. I don't want to do any damage to the gear - pully or shaft. I had an idea yesterday and that is to check everything one last time for 1 cyl to tdc and cut the belt and pull both off connected and try to seperate once I have it off. That's probably the only way I can think of.
I just want to make sure the timing is on. I read in the book that after you have it assembled you can manually turn the engine and try to see if it moves freely to make sure the valves aren't binding. I know this is a touchy thing - any other suggestions on that proceedure would be appreciated.
