Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > General Discussion
General Discussion All general comments or enquiries go here. Website, club oriented, or general Skyline banter.
Old 10-20-2001, 06:49 AM
NiteskyR's Avatar
NiteskyR NiteskyR is offline
Send a message via AIM to NiteskyR
Question timing belt
hi all
ive decided 2 replace my timing belt , have heard of kevlar ones,
do any of u know where i might get one?
or a site that will advise.
Old 10-21-2001, 04:28 AM
GTS-4 Ben's Avatar
GTS-4 Ben GTS-4 Ben is offline
Send a message via ICQ to GTS-4 Ben
Why would you want a Kevlar one??
They don't need to be replaced very often and on that RB0DET blowing the cam belt does not cause damage..
SDU Southland Moderator
Old 10-21-2001, 06:47 AM
NiteskyR's Avatar
ben, re kevlar belt .Im doing the job anyway so i might as well put a kevlar one in. ( peace of mind)
how is that so, that if it does break , there will be no damage to the engine?
Old 10-21-2001, 05:34 PM
GTS-4 Ben's Avatar
The way the valves etc are setup on a RB20. Unlike a Honda, they will not be damaged if the cam belt breaks.
Old 10-24-2001, 10:48 AM
NiteskyR's Avatar
thanks ben , its a Rb25 though , i presume thats set up the same. just bigger bores.
ill just get standard belt then
Old 11-10-2001, 02:58 AM
BDP BDP is offline
are you sure the RB20DET and RB25DET are non interference engines??? - it seems weird that everyone is so paranoid about changing timing belts if a timing belt failure wont cause any damage...
Old 11-10-2001, 04:01 AM
Dak Dak is offline
DET's maybe, but if a DE breaks a belt kiss the motor goodbye.
Cheers, Dak.
Old 11-10-2001, 09:07 AM
NiteskyR's Avatar
hmmmmm
Old 11-11-2001, 11:52 AM
WDRacing WDRacing is offline
Broke mine while it was running no valve contact. You turn it over all day with no problems.
WD
WDRacing
Its all in the name
Old 11-11-2001, 03:34 PM
R31Heaven R31Heaven is offline
Cam Belts
Dont try it on a RB30E breakies
Old 11-11-2001, 03:43 PM
verboom verboom is offline
I'd like for someone with a bit more car knowledge than me to explain in a bit more detail why exactally it wouldn't bust the engine.
Old 11-13-2001, 01:44 AM
BDP BDP is offline
WDRacing and Forsteen are the main RB20DET engine builders on SDU as far as i know. but reguarding the engine damage - on an interference engine, if you extend the valves to the full open position and put the piston to the top of its travel - they will touch, therefore if the timing belt breaks - the valves can move around randomly and as the pistons go up and down they can come in contact with the valves and bend them also can damage the head i think.
thats as good as i can manage :P
Old 11-13-2001, 01:49 PM
Ok here's how it goes. If I take off my timing belt and turn over my engine the valves do not come in contact with the piston. This is because of the length of valve and cam lift. I have had my head and cams installed and rotated my crank atleast 15 times. No contact...
I rebuilt my engine 6 times. I changed my head 3 times. I have changed more pistons then I care to. Believe it or not. Makes no real difference to me. This info only pertains to the RB20DET.
WD
WDRacing
Its all in the name
Old 11-13-2001, 03:04 PM
Timming Belt
On an RB30 the Valves DO hit the pistons on the SOHC engine mega mess if this happens, so be careful of your change over times. They recommend every 100,000k's I change mine every 70,000 to be on the safe side.
Old 11-14-2001, 06:27 PM
Forsteen Forsteen is offline
I'm glad for the compliment BDP, but WDRacing and TheCamel are the best sources for engine builds. Me?, I'm no expert. I am just learning to figure out alot of what is going on. Learning how a car works is not difficult, but when problems arise, troubleshooting, or tuning, I go to WD or Camel for help.
"I wash my hands of those who imagine chattering to be knowledge, silence to be ignorance, and affection to be art." Kahlil Gibran
http://www.skyline-racing-tech.com
2000 Mirage 1.8 Timing Belt changeout Mangoacn Mirage 0 12-18-2009 08:51 PM
Timing belt walk HELP! 91TSi_ Engine, Transmission and Drivetrain 13 10-15-2009 02:47 PM
Timing Belt kp055174 Accord/TSX/Accord Hybrid 2 07-27-2009 12:00 PM
timing belt and water pump :( cobraprince 3000GT/Stealth 17 07-09-2009 03:28 AM
How to change timing belt? RainSpirit44 SVX 2 03-25-2009 04:30 AM
