Old 03-12-2003, 02:56 AM
york2600 york2600 is offline
Send a message via AIM to york2600
Anything to consider with a 94 GSR tranny on a B20
Is there anything that needs to be done to make the B20 take a 94 GSR tranny with a lightened flywheel and ACT stage 1 clutch?
94 Integra GSR Coupe
Mods: Professionally Built B20/VTEC: B18C1 head w/ pocket port, JE oversized pistons, Eagle Rods, block guard, ARP head studs, Skunk2 Intake Manifold, STR Throttle Body, AEM CAI, AEM Fuel Rail/Regulator, RC Engineering 280CC injectors, Denso Iridium Plugs, Magnacor Wires, DC Sports 4-2-1 SS Header, Greddy Evo Exhaust, ACT Stage 1 clutch W/ ACT flywheel, Apexi SAFC & Revspeed Meter, and many other toys.
Old 03-12-2003, 06:33 AM
94civic's Avatar
94civic 94civic is offline
i don't think you have to do anything, it just bolts right up. the reason why is because the gsr and b20 are both b series engines and most of their parts are interchangeable.
1994 civic ex - b16a sir2 w/lsd
too much to list
http://www.cardomain.com/memberpage/423478
Old 03-12-2003, 10:58 AM
I thought the b20 was a b18b with a 84mm bore instead of a 81mm?
Old 03-12-2003, 12:29 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
maybe the bore size might be different, idk if it is. but your question is about the tranny so bore size doesnt matter.
what you might have to do is get all hte parts from the tranny your using, like your using a 94 gsr tranny, so you might have to use the 94 gsr flywheel with clutch. but idk for sure. it should bolt up though
Team Lonely Drivers
94 Integra B20 engine swap with Auto tranny J4justin How-To's and Walk-Through's 1 03-15-2007 04:09 PM
What is an LS's safe redline with GSR tranny? DeleriouS Let's get Technical! 2 09-28-2004 09:33 AM
blown b20 with b18b tranny? emerge Let's get Technical! 4 05-14-2004 11:53 PM
Gsr Vs B20 Sargento69 '88 - '91 Civic | CRX | Wagon | Shuttlee 3 12-05-2003 08:31 PM
B20 with GSR head: Valve clearance problems york2600 Engineering/ Technical 0 03-26-2003 06:03 PM
