Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 09-27-2004, 10:03 PM
DeleriouS's Avatar
DeleriouS DeleriouS is offline
Send a message via AIM to DeleriouS
What is an LS's safe redline with GSR tranny?
Does anyone know what the ratio's are of the LS, GSR, and Type-R tranny? Thanks
also, i was looking at my manual from my integra, and it said that GSR tranny's top out at 110mph (MAX). What is the governed redline on the GSR? What is a safe redline that i can bring my LS integra(stock internals) to? Because i know that the vtec has a higher redline. I don't want to create valve-float, so what is the max rmp i can shift at? thank you for your info
95' LS Integra
5spd
DC Header (4-2-1)
HKS Super Dragger Exhaust
Skunk2 Short throw shifter
Ground Control Coilovers
Strut Bar
-SOON to be putting in a JDM B16 hydraulic tranny with lightened flywheel and stage III clutch
-SOON to be "home made" turbo charging (goal = 12psi)
-GOAL = 250-300hp with stock internals(probably not reachable)
Old 09-27-2004, 11:06 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
dont take your ls above the stock revlimit on stock internals, honda put a revlimit there for a reason
Team Lonely Drivers
Old 09-28-2004, 09:33 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: What is an LS's safe redline with GSR tranny?
Yep. You gotta build up the motor to handle the revving. LS are not made to rev high.
