Go Back   Automotive Forums Car Chat > Racing > Initial D
Initial D Japanese Cartoon Racing, Drifting and more.
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 03-02-2003, 12:29 PM
dbartoschek's Avatar
dbartoschek dbartoschek is offline
how to drift a Front-drive?
How doy ou drift a fwd car? I know it's easy to do in snow of loose gravel or something, but how about on the pavement......also...is it possible to do doughnuts in a fwd.....someone told me this guy was doing doughnuts in a sunfire....i find it hard to picture.
Not mine, but a nice one! I have one though, 1994 Bonneville, new vehicle section doesn't let you list more then 1 car.
Old 03-02-2003, 01:21 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
As someone else has put it, FWD don't drift, they drag ass. The only way to drift a FWD is to E-brake it. Now doing donuts in a FWD, if I am correct you have to go in reverse to do a donut
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 03-02-2003, 08:49 PM
Suislide's Avatar
Suislide Suislide is offline
Re: how to drift a Front-drive?
2 words: you can't.
ass dragging.
-Brian
2013 Subaru BRZ Sport-Tech 6MT. Not stock.
Old 03-02-2003, 09:07 PM
flylwsi flylwsi is offline
Send a message via AIM to flylwsi
much agreed.
you can get a fwd car to oversteer, but it's not drifting...
you can control the "spin" that would occur, but you can't induce it and control it the same ways you can with rwd.
you can look like you're drifting, and use some of the same techniques, but an fwd car does drift, b/c you can't use the gas to control the rear wheels, which means you "drift/slide" until they grip, instead of like a rwd car where you can control it...
Old 03-02-2003, 10:39 PM
Ragnarok043's Avatar
Ragnarok043 Ragnarok043 is offline
Send a message via AIM to Ragnarok043
yes there is a technique to drift FWD cars, its called left foot braking. though this technique is mainly used for rallies its possible to use it on pavement. granted that this technique is very hard to learn but none the less it is possible to drift in a FWD.
Old 03-03-2003, 01:56 AM
Cbass's Avatar
Cbass Cbass is offline
Send a message via ICQ to Cbass Send a message via AIM to Cbass Send a message via MSN to Cbass Send a message via Yahoo to Cbass
It's possible to inertia drift a FWD car using the left foot braking technique as Ragnarok explains. There isn't any real benefit to it most of the time, except on some hairpins or loose surfaces.
It's simple enough, you set up your suspension for a more or less even balance, and brake to transfer weight to the front wheels, allowing the rear wheels to lose grip before the front wheels, and inducing drift.
Actually, the ironic thing is, FWD cars can only do true inertia drift(aside from ebrake lock), wheras most RWD "drifters" are just using power to overcome the traction of the rear tires :hehehe:
Connor - Porsche Nazi since 2001, VW defiler since 2004
This here's a Fabrication forum!
My lugnut requires more torque than your LS1 makes.
Old 03-03-2003, 03:44 AM
finally someone agrees that FWDs can drift, im tired of people preaching that FWDs cant.
Old 03-03-2003, 04:04 AM
Monkey-Magic-S15-R's Avatar
Monkey-Magic-S15-R Monkey-Magic-S15-R is offline
Banned
handbrake feint brake throttle lalalala very difficult. its an FF drift. There's a link to a drifting tips page in this forum somewhere just search for it
Old 03-03-2003, 06:04 PM
Suislide's Avatar
it's still not drifting. it's just dragging. drifting is using power to overcome the loss of traction in the rear wheels (the drive wheels) and an FF car can't very well do that, now can it?
-Brian
Old 03-03-2003, 06:14 PM
Tony's Avatar
TLD Member #1
here we go again... haven't we went over how many different types of driftin there is? I understand monkey's point, if you can get a FWD to drift without e-brake, that is a true inertia drift, but if you use the e-brake, that is ass draggin. Overpowering the car over is a different type of drift than an inertia drift.
Tony
Old 03-04-2003, 04:39 PM
ok, the point is that you can't overpower the rear wheels of a fwd car.
that's the point.
you can't control the rear wheels by stomping the gas and keeping them spinning.
so you're not drifting the car.
it may look like it, but you're not if you're going by the definition.
if i drive my fwd car hard into a corner and it oversteers, i'm not going to say i was drifting, b/c i can't really control it and keep the ass out there.
that's the point.
Old 03-04-2003, 05:30 PM
Tony's Avatar
TLD Member #1
I think there are different defintions of what a drift is. My first answer to this question was, no you can't drift a FWD, but after a few people comments, I have changed my mind, and I agree with them. You can drift a FWD, just takes a lot more skill.
Tony
Old 03-04-2003, 05:38 PM
in the true defintion of a drift, you can't get a fwd car to drift.
i feel the same way you do, but i don't consider that drifting.
drifting means you can control, usually with modulation of the gas pedal, the rear wheels, which are being driven by the engine.
in that case, fwd can't drift, b/c the rear wheels are just along for the ride.
my major keypoint here is that if you're drifting a rwd car, and wish to prolong the drift, step on the gas and keep em spinning.
you can't do that in a fwd car. so it's not really drifting.
Old 03-04-2003, 06:04 PM
read up on Left Foot Braking and come back to meyou dont need to over power the rear wheels to drift. as long as you can break traction without the use of the hand brake.
http://www.modernracer.com/tips/leftfootbraking.html
Old 03-04-2003, 06:19 PM
v10_viper's Avatar
v10_viper v10_viper is offline
Send a message via MSN to v10_viper
I've personally done it myself, with our minivan, reason why is there is hardly anything in the rear so it's quite light back there so it gave a nice little swing out but it tucked right back in, now if that were rear wheel you could control it and keep it out for a few extra seconds. It is definately possible when there isn't much weight over the rear axle. I will stand behind this, and prove it if I have to!
Wait a minute, you mean to say a bottle of pop is bigger than your engine??
"Pain is weakness leaving your body"
There is NO replacement, for displacement...
2007 Kawasaki ZX10-R S.E.
A4 Easily Driving Thru 1 Foot of Snow!!! strokera4 '94 - '01 1 12-10-2013 06:30 AM
Audi A4 Driving Thru 1 Foot of Snow!! strokera4 Car Videos 0 12-06-2010 02:33 PM
How to remove front drive shaft Sedlik Envoy 5 08-23-2010 07:41 PM
FOR TRADE: New 97-99 Drift front for 97-99 stock front loco69boyz Off-Topic 5 03-12-2005 01:27 AM
Closed Thread
