Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 02-11-2003, 06:23 PM
cann cann is offline
Programming Keys and Remote
Does anyone have info on programming the key or the keyless entry remote for a 2001 sentra.
Thanks
Eric
Old 02-11-2003, 07:27 PM
1 Problem Solved
https://www.keylessride.com
Old 04-01-2003, 06:23 PM
unossingh unossingh is offline
try this
A: Every manufacturer has different means of programming for a replacement remote. The Nissan dealer has a choice of using a computer scan tool known as the Consult-II or the conventional method that you can do yourself. It's not too tough as long as you're using the correct remote. Get in the vehicle. Close and lock all doors utilizing the driver's power-door lock/unlock switch. Insert and remove the ignition key more than six times within a 10-second period (at a rate of one insertion/removal cycle per second). Don't rush the process, and be sure the key is completely withdrawn from the ignition-key cylinder each time it's removed. Turn the ignition to the ACC position and press any button on the remote one time. The hazard lights should flash twice, letting you know your mission is a success. If you were going to program more than one remote, you'd simply unlock and lock the doors once again with the driver's switch and press the one button, one time, on the second remote. The procedure is completed by turning the ignition off, unlocking with the driver's switch, and opening the driver's door.
Old 11-02-2005, 06:50 AM
kcwtst kcwtst is offline
Angry Key only programming for 2000 Nissan Altima
I have looked at the programming information and it seems to be only for key fobs. I just want to program the Key only and later may purchase a key fob. Can anyone help me.
kcwtst
Old 11-05-2005, 05:31 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Re: Programming Keys and Remote
If you have a chip inside your key for an immobilizer system (makes it so you cant start the car with a screwdriver), then you need to go to the dealer for the keys so they can be programmed to your car.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 11-06-2005, 02:09 AM
Chiquae07's Avatar
Chiquae07 Chiquae07 is offline
Send a message via AIM to Chiquae07 Send a message via MSN to Chiquae07
Nissan Dealer to program your keys. if THEY ARE NOT NISSAN KEYS, THE COPIES WILL NOT WORK. its just a lil somethin that i was reading in my manual the other day.
2008 Mazda 6 ATX 2.3 Liters of Slowness
For those 9 seconds it takes me to reach 60mph, will be the most fun ill have in this car.
2005 toyota camry LE master key and remote programming ny17 Camry/Camry Hybrid/Vista 2 06-23-2009 03:50 PM
Transponder Key and Remote Programming Resources TrendyOne Camry/Camry Hybrid/Vista 1 04-19-2009 11:26 AM
How to program key fob remote? AccElan01 CTS and CTS-V 2 08-18-2005 09:22 AM
Programming PK3 key and remote starter baby141 Venture 2 08-12-2005 08:48 AM
Just Programmed a new key and remote on my 2003 SN95GT50 Silhouette 2 06-08-2004 11:25 AM
