Old 02-08-2003, 09:34 PM
bloodhound43 bloodhound43 is offline
how hard? 2.2L to the 2.4 DOHC
How hard is is to make the 2.4 DOHC engine fit into a base model 2.2 cav?
Old 02-12-2003, 07:49 AM
I need some advice plez.
*cough (bump)
Old 02-12-2003, 08:12 AM
bowtiebandit's Avatar
bowtiebandit bowtiebandit is offline
Send a message via AIM to bowtiebandit
Cant imagine it would be to hard. I think all the body mounts are the same but the engine portion may be different. You have to get all the electronics though.
Shop Foreman
Corvette Specialist
A.S.E. Master Technician
L1 Certified
A.S.E. Master Machinist
GM Certified Technician
Old 02-12-2003, 09:37 AM
Shortbus Shortbus is offline
Blah blah blah
Send a message via AIM to Shortbus
Salvage yards usually have the compatibility catalogs.
I have done some light research in my parts catalog. Here is what I have found.
The front engine mount is different, which is minor. The Powertrain control module is the same but it will have to be reporgrammed.
The engine wiring harness is different they are around 1000.00 new but if you find a donor car this should be an easy swap.
The transaxle is also different but in gear ratio only. The 2.4 trans uses a 3.91 final drive where the 2.2 uses 3.18 and 3.63. I belive this is the only difference so the 2.4 should bolt right up to the 2.2's transaxle.
Like I said if you get a donor car the swap should work
96 Toy Camry LE 2.2L 5S-FE parts needed Maulana Classifieds 0 03-18-2010 12:17 AM
GM 2.2L OHV DOHC: Interference or NON-Interference sharpnshine General Discussions 1 04-27-2009 07:21 PM
how hard is it to swap 4 cyl to a v-6 dankdog 626/Capella/Capella Wagon 13 04-28-2006 11:19 PM
how to change spark plugs 3.4 dohc tela4422 Monte Carlo 4 02-12-2006 06:58 AM
2.2L into 2.4L/2.3L Schotty Cavalier 2 07-25-2004 09:22 PM
