Go Back   Automotive Forums Car Chat > Mazda > 626/Capella/Capella Wagon
Old 01-10-2006, 01:16 PM
dankdog dankdog is offline
how hard is it to swap 4 cyl to a v-6
I have a 93 626 and it has a 4 cyl.But i want the v-6 how hard is it to swap and what is involved in it.I am almost done getting the blowen moter out and i want to know if i shouled get the 6 cyl i found whith trans.But i have to know whats all involved in it first. someone plz help it needs to be a lot faster.
Old 01-10-2006, 02:45 PM
mazdatech177 mazdatech177 is offline
Re: how hard is it to swap 4 cyl to a v-6
go buy a car that is a lot faster. itll be cheaper than swapping over... trust me
Old 01-20-2006, 06:31 PM
rjitzsu rjitzsu is offline
agreed. harness, pcm, all mounts, axles... waste of money. put another 2.0 in it and drive it for another 150K miles.
Old 02-10-2006, 12:39 PM
Trigggl's Avatar
Trigggl Trigggl is offline
I have a 95 626 with the V-6. It pulls like a champ when it's running right. Perhaps you have more patience than I? I just put in a new rack and pinion. It has all new belts including timing. If you're interested, let me know.
Greg
97 Rodeo 2.6L 2wd 5speed green and paid for
Wife's car:
06 Outback 4cyl 5speed green
Old 02-23-2006, 11:56 AM
Kain043 Kain043 is offline
I too am thinking of doing an I-4 to V6 motor swap....any info or tips?
On a related note, i'm thinking of putting the turbo (and all the related equipment) from an 88' MX-6 in my current 4 Cyl. Anyone else do this at all?
Old 03-03-2006, 08:31 PM
kjbuente kjbuente is offline
Send a message via MSN to kjbuente Send a message via Yahoo to kjbuente
If you decide to do a swap, go with an engine called "KL-ZE" These are more reliable and stronger engines. The stock V-6 give about 165HP, while these ZE's can put out over 220HP if you know how to set them up corectly. Once set, you can praticly run to the ground and start right up! I love these engines! (If you know what your really doing and know a good few people with connection, I'm sure you can get over 300HP! I heard of a few but I can not say if they are ture).
As far as swapping, engine, tranny, axels, and ecu are your main issues. You'll have some minor ones but theyll should be easy.
Personally, if you have a manual tranny, GO FOR IT!!! If it is an auto tranny, your better of with a differnt car.
If it ain't broken, Don't fix it!
Old 03-04-2006, 12:52 AM
Thumbs up Re: how hard is it to swap 4 cyl to a v-6
cool. thanks! currently have a manual, so no problems there.
Old 03-04-2006, 05:54 PM
Then I say go for it!!!!
Old 03-10-2006, 07:30 AM
MazdaManiac1136 MazdaManiac1136 is offline
i have an inline 4 cylinder engine in my car and i was thinking about trying to find a motor from the new impala and see if i could transplant it into my 91 626. Any comments
MazdaManiac
Old 03-10-2006, 04:22 PM
About how much does a KL-ZE cost?
MazdaManiac
Old 03-11-2006, 04:00 PM
Sorry for late reply,
Anyways, I do not know much about the '91 models. But I belive little of it is the same, I think. But putting a newer impala engine in there would be a pain in the arse! As most people already know, these cars are the same as a ford probe. So sticking a GM engine in there would be hard as hell!
As far as how much a KL-ZE engine costs, check on eBay. Just make sure that it is a ture ZE engine. Send me a PM and I'll show ya site that will help you out with finding out if it is a true ZE, plus some more performace tips.
Old 03-11-2006, 04:03 PM
Also, If anyone has the Idea of putting a turbo on the ZE engine, DON'T! You'll be wasting your money. A ZE can burnout at 4psi, while the DE (stock) can handle 12psi easily.
Edit: Just to let you know, if anyone is thinking about the 300hp+ range. It does not matter what engine you have. By the time that you replace all the stuff needed to handle all the Hp, it'll be a new engine all together.
The only differnce between theese engines are that one is designed for the extra HP. Other than that, they are exactly the same.
Old 04-12-2006, 02:35 PM
i heard that i could cost like 3 grand to get the engine bay customized to fit the new v6 engine.ei motor mounts
MazdaManiac
Old 04-28-2006, 11:19 PM
Well,
If you got a drill, metal, cutting tourch, and some welding skills. Then you can attach the V6 motor mounts just fine. YOu'll have to move some mounts around, add more mounts. And some mounts just need to be replaced so it can handle the V6.
The best thing that you can do is drop the motor in and see how well they line up. Some will just need the v6 version of the mount. And if you see one missing, you'll have to add it.
Since I am not currently doing this myself, it would be nice if somebody took the time and noted this for everyone. For example, what mount needed moved, what one needed added. If I could get a hold of a I4 I could be able to look myself. I will do my best to see what the manual says. I'll get back to you guys when I do. If somebody beats me to the puch. please post.
Also just wanted to let ya all know. The trannys from a 4 to a 6 have differnt bolt patterns. So, just to let ya know. Kinda figured it was a little important.
