Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 02-06-2003, 05:05 PM
Hammer Head Hammer Head is offline
whats the diff 4thgen 5thgen?
they both have the same engine,what did they do to squeaze more hp out of the 5thgen? Who knows?
Old 02-06-2003, 06:00 PM
bk2kmax's Avatar
bk2kmax bk2kmax is offline
Re: whats the diff 4thgen 5thgen?
I know that the muffler system on the 5th gen is one of the changes Nissan did to vary when the valves open for cruising or WOT. I believe the design of the stock air boxes are different as well.
The difference though in the 4th & 5th gen is almost a moot point because the 4th gens are lighter so the difference in the hp was done to make up for all the extra weight the 5th gen Max gained.
The 4th gens due to their lighter weight have better 0-60 times and the 5thgen usually catches up with the 4thgen before the 1/4 and pass them due to the way the vvt shift adjustments in the engine and the valves on the muffler opening for WOT at the higher end< this is the reason 4th genners opt for the MEVI to be able to continue pulling higher in the rev range and on the top end of especially 3rd gear.
I'm not certain as to what other changes were made but I know that the muffler is one of the major ones.
By the way, it should read bk2k3Max, not bk2kmax.
Old 02-06-2003, 10:10 PM
Pick Pick is offline
Maybe gear ratios.
Old 02-06-2003, 10:11 PM
Or combustion timing.
Old 02-06-2003, 11:35 PM
n1smo's Avatar
n1smo n1smo is offline
Send a message via AIM to n1smo
The 5th gen has variable intake. The 3.0 has 2 intake runners... it switches from long intake runner to the short at around 5000 RPM... If you look at the dyno sheets, the 4th gen runs out of breath and HP begins to drop at 5000 RPM while the 5th gen keeps making HP all the way to the red line...
2004 Mazda 3
2003 Maxima SE Titanium Edition
Old 02-06-2003, 11:44 PM
MaximusGTR's Avatar
MaximusGTR MaximusGTR is offline
Does the 5th gen have the limited slip diff. option?
"SHIFT_"
Old 02-07-2003, 12:46 AM
thrasher thrasher is offline
yo bk, i didn't think the 5th gen 3.0 liters had vvt...are you sure about that one? that is one of that factors that added to the power gain in the vq35. correct me if i am wrong, anyone
Old 02-07-2003, 06:18 PM
bk2kmax's Avatar
Thrasher, you are correct, it was a typo that i couldn't catch before I hit the Submit button, that should've only been credited to the muffler for the way it varies the opening and closing of the valves (BTW, are made from Inconel)<a metal based substance used in high speed military aircraft.
Old 02-07-2003, 06:57 PM
maximus, i know the vq35 5th gen's have the limited slip diif option (SE) and i think the 2k1 AE had it as well...not 100% sure though
Whats the diff between Evo and the Eclipse GSX? mellowboy Lancer 17 08-25-2004 03:26 PM
Whats the diff in the N2O setups? doug294 Forced Induction 2 01-04-2004 10:33 PM
whats the diff in headers? strodda Accord/TSX/Accord Hybrid 6 02-19-2002 07:40 PM
whats the diff?? evergreen Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 5 10-10-2001 07:51 PM
what the diff with GTR 34 and GTR 34 V-spec? Derek888 General Discussion 18 10-01-2001 11:41 PM
