Old 01-27-2003, 11:53 PM
YellowMaranello's Avatar
YellowMaranello YellowMaranello is offline
Send a message via AIM to YellowMaranello
Anti-lag (misfiring) systems...
When do these fire? When you let up off the gas, push the gas, or both?
Old 01-28-2003, 04:56 AM
ales's Avatar
ales ales is offline
Forza Schumacher
When you lift
Old 01-28-2003, 05:34 PM
Originally posted by ales
When you lift
Ah, thanks.
Old 01-29-2003, 12:37 AM
replicant_008's Avatar
replicant_008 replicant_008 is offline
Anti-Lag doesn't cause a misfire at all. When you have the car on boost the turbos are spinning with the exhaust gases. Trouble is when you throttle off, less exhaust gas is produced and therefore the impellers slow in velocity - which reduces the initial boost available when you open the throttle - hence lag.
Anti-Lag can work in three ways - directly inject fuel into the exhaust manifold where it burns and creates more gas to keep the impellers spinning (but fraught with issues involving very hot manifolds and fuel being in the same postal code), secondly when you lift off, the ECU retards the ignition but maintains injector rate so some of the fuel passed into the inlet manifold hasn't had time to completely burned by the time it is forced into the exhaust manifold out of the cylinder head - this means you have less power when you lift off but the incompletely burnt fuel gets to expand in the exhaust manifold which provides pressure to keep the impellers spinning, the third is to use a combination of both techniques.
The big issue is heat from the burning gases in the manifold - expect your manifolds not to last, higher underbonnet temperatures and potential to create abnormal heat along the exhaust
1997 grand prix anti-theft system components Konstantin Grand Prix 8 10-13-2010 11:20 AM
Anti Lag + Huge Turbo = Streetable? flip888 Forced Induction 9 09-02-2006 04:23 AM
anti-lock braking system. aeholton Ram Pickup | Ram SRT10 0 07-15-2004 12:18 PM
anti lag system c32b1 NSX Let's get Technical! 4 02-25-2004 02:18 AM
Anti-Lag System (Misfiring System) LanEvo Rally 1 07-30-2003 10:46 PM
