Old 10-10-2010, 03:31 PM
Konstantin Konstantin is offline
1997 grand prix anti-theft system components
I am looking to upgrade my 1997 Grand Prix with the factory anti-theft system and I am trying to compile a parts list, so far i have not been having much luck locating what is needed for this to work, any input into what is needed would be greatly appreciated.
Old 10-10-2010, 04:17 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: 1997 grand prix anti-theft system components
Why Factory?
What specific anti-theft system did you want to add?
PK3 VATS transponder key system, or the alarm system?
You may just be better off installing an aftermarket system which will be easier/cheaper/ and while your at it, you could install a remote starter.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 10-10-2010, 08:42 PM
I'm looking to install the factory alarm system. I already thought about a third party remote started but thats a little too expensive right now and I can pull the parts for a factory setup from the from the junkyard
Old 10-11-2010, 10:42 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Are you referring to the orginal factory content theft alarm system for the 1997 year? What model GP do you have? I believe your current body control module (BCM) doesn't support it.
Tim, 1997 models did not have Passkey 3 or even the Passkey 2 with the key resistor pellet in reference to the VATS immobilizer system.
Timeslip 08/12/06
AF Community Guidelines
Old 10-12-2010, 02:54 AM
I have a 1997 GP SE, could I not just swap the BCM from a 97 GP that did have the alarm installed? Also my car currently has the remote keyless entry system if that makes any difference in what would be needed
Old 10-12-2010, 09:45 AM
andretti andretti is offline
It would be a lot of work to change it over.
-You would need install the door lock tumbler switches and wiring.
-Change over the forward wiring harness and add the theft deterrent for headlamp feed & output.
-updated BCM.
-Change over the IP harness and add in the top dah security indicator.
- ...and I'm sure others here can add to this list.
Old 10-12-2010, 02:08 PM
I already have the remote entry option which can lock/unlock the doors. Would I need a different set of wiring and switches for the alarm or can I use the existing parts?
Old 10-12-2010, 08:38 PM
The tumpler/latch switch is separate part from the cylinder power lock solinoid.
Also, i missed "relay" in the second line, s/b theft deterrent relay.
Old 10-13-2010, 10:20 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
the factory alarm system is operated through the BCM. The BCM's are different between ones with just keyless entry vs factory keyless entry/anti-theft. Since the BCM's then need to be flashed with your VIN-specific information, I don't believe it is possible to add anti-theft to a vehicle that came without. You can try to call a dealer to see if just swapping the BCM's and having the new one flashed with the anti-theft content would work, but I doubt it. It would be much less costly to just add an aftermarket alarm system, as the replacement BCM would run you almost $233 retail, plus the cost of programming and that's assuming this upgrade is possible.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
anti theft system/2005 grand prix davidhill62 Grand Prix 0 08-18-2007 07:40 AM
mercury marquis anti theft system chipper3 Grand Marquis 1 10-27-2004 06:40 PM
Help with anti-theft system! buechine LS | MKZ 1 04-02-2004 08:47 AM
Anti theft system ubergeek C/K 1 08-05-2003 05:44 PM
'95 Suburban anti-theft system question bobginpgh Suburban 0 05-18-2002 05:48 PM
Tags
1997 , alarm , anti-theft , grand , prix
