Old 01-17-2003, 12:52 PM
flyingmachine flyingmachine is offline
help with setting decals
Finally get to touch my models again, but I'm having a tough time setting the smaller decals for a Tamiya WRC corolla. The smaller ones that wraps aroud the fire extinguisher simply would not conform to the round shape. I've even gone to the point of soaking them in decal set to soften them, but once they dry, they simply peel themselves off the cylinder. What am I doing wrong? Thanks!
Old 01-17-2003, 01:19 PM
Diesel2NR's Avatar
Diesel2NR Diesel2NR is offline
Send a message via AIM to Diesel2NR Send a message via Yahoo to Diesel2NR
are you using decal setting solutions and solvents, or just water? The setting solution is put on while the decal is soaking after being dipped in water. That helps it stick. Then, after the decal has been applied and has been drying for about an hour, you can put some solvent over it, which essentially melts the decal, allowing it to conform to even the smallest spaces of the part. Then you can put some wax over it or clearcoat it to help keep it in place. Hope that helps some
Old 01-17-2003, 01:26 PM
primera man's Avatar
"P-Man"
A warm cloth over the decal or use a hair dryer to help it works well.
View All My Models Here.
Old 01-17-2003, 01:42 PM
935k3's Avatar
935k3 935k3 is offline
A little white glue(like Elemer's or craft glue)under the decal will help it stick.
Old 01-17-2003, 04:54 PM
I'm using setting solution to wet the decal b4 I put them on the surface. I've never had problem before, but since the fire extinguisher is so small w/ so much curvature the decals wants to lift it self off the surface. Would using hotter water help soften the decals more? thanks!
Need help with custom decal cjsbosox Car Modeling 3 02-26-2010 04:20 PM
HELP with setting timing 1961 389cid dfontalbert General Discussion 5 06-26-2007 08:15 AM
Help with Warsteiner decals Kiss My Axe Car Modeling 1 12-14-2006 07:07 AM
Need help with a decal Jon MW Car Modeling 0 07-30-2004 12:37 PM
Help with settings on Razo Up shift indicator 02SilverSiHB '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 20 07-25-2004 10:53 AM
