Old 07-26-2003, 05:18 PM
02SilverSiHB's Avatar
02SilverSiHB 02SilverSiHB is offline
Help with settings on Razo Up shift indicator
For those not familiar with it, here it is:
shift light
control unit for selecting rpm's for green and rpms for red lights
The Red comes on when you reach the max rpms you want.
The green lights up when you are at the rpm you want for launching at the strip. This can also be set for autocross to where if you fall below the desired rpm it will light up. You just press a switch for the desired affect you want, either above or below the preset rpms.
When I start the car, the green light is on and I have it set to come on when it goes below a certain rpm (not sure what rpm, but the knob is turned to a low setting)...to test it out. I rev it all the way and the light doesn't go off. The red one doesn't come on either when I hit the rev limiter and I have the red rpm set to a low setting to come on.
There are 6 switches in the rear and I have no idea what to set them at. The manual is written in poor english, but sounds like I should have the switch down for 4, meaning I have 4 cylinders. So I'm not sure if I have that part correct, or if I have the thin black wire spliced into the wrong blue wire.
2002 Civic Si
301whp and 255wtq at 10psi
263whp and 219wtq at 7psi
Old 07-27-2003, 12:15 AM
B16EJ1's Avatar
B16EJ1 B16EJ1 is offline
Is'nt that what the tachometer is for anyways?
Old 07-27-2003, 08:00 AM
I don't think staring at my tach is a good idea while autocrossing or at the drag strip.
2002 Civic Si
Old 07-27-2003, 08:49 AM
never mind guys. I got it working now. I had the back set correctly....number 4 down and the rest of the tabs up. I just had the wrong blue wire, go figure The blue wire was on the far left connector to the ecu.
2002 Civic Si
Old 07-27-2003, 07:38 PM
B16EJ1's Avatar
How the hell do you think everyone else does it? You know what the problem is? You stare at it. You're supposed to quickly glance at it.
Old 07-27-2003, 09:13 PM
When I'm autocrossing, I don't have the time to glance at it, when I'm going through a slalom and into a 90 degree turn, then through some more slalom and more 90 degree turn. I guess you're the man
For those that might get this and need a how to
All the components
Mounted the shift light just behind the steering wheel
Lead the wire from the shift light behind the dash/steering wheel
Have your dash around the shifter removed to help lead that same wire through, towards your glove compartment box
Make sure to zip tie the wire away from the shifter
Zip tie the wire again behind the glove compartment
Use this as a grounding point for the ground wire...behind the glove box
For the power wire. Take the red wire and splice it into the green/black wire with silver dots. This wire can be found above your dead pedal. It's hot, so once you turn the key on, you have power.
For the rpm wire...splice it into the blue wire on the far left ecu connector
Now that everything is connected you can put the controller in the glove box. Before you do, in the back of the controller, make sure number 4 is down and that the rest of the white tabs are up. This is to let the controller know it is getting readings from a 4 cylinder engine.
Now you can adjust the turn knob for the red and green light to where you want them to come on. For the green light, you can have the push button on the controller set to the down position for when you rpms go below what you have it set for. Put the button in the up position to have the green light come on over the set rpms.
Hopefully this link will work, so if you need higher res pics you can go here and select each individual pic
http://members17.clubphoto.com/hill7...ner-2761.phtml
2002 Civic Si
Old 07-27-2003, 10:45 PM
B16EJ1's Avatar
I don't think so. I think that everyone else that autox's and hits the drags without your little flashy toy is and you're just not.
Old 07-28-2003, 06:06 AM
okay man, I've seen about 10 other people with this thing...escpecially in the new si. We hit the rev limiter before you know it. You don't have to like, everyone has their own thing...relax.
2002 Civic Si
Old 07-28-2003, 06:07 AM
oh, and it doesn't flash it just lights up.
2002 Civic Si
Old 07-21-2004, 11:41 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
(ROFL, I've been searching all over the net for a clean tut; I should've known to check af first Sorry to bring up an old thread btw)
OMG! Thanks for the tut! I was hesitating to buy one of these, since i was 99% sure i wouldn't be able to install it correctly, and thus breaking something.
Where did you get yours and for how much?
Old 07-22-2004, 04:11 AM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: Help with settings on Razo Up shift indicator
this does not cut it
once again, it is an old thread.....and if you are going to ask one single person a question, use the PM function.
Empty Pockets Racing Member #1
Old 07-22-2004, 07:28 AM
I got mine from a local shop because I was impatient, the best price is at www.optauto.com
2002 Civic Si
Old 07-22-2004, 01:44 PM
SiGNAL748's Avatar
Re: Re: Help with settings on Razo Up shift indicator
Old 07-24-2004, 05:23 AM
GScivic7's Avatar
it's all good, i used to dumb shit like this too, you live and learn. just telling you so you don't make the same mistake
Old 07-24-2004, 02:20 PM
lol, what are you going to do there tough internet talking man!? hahahaha, how lame!
2002 Civic Si
