Old 01-17-2003, 05:52 AM
walt0023 walt0023 is offline
Send a message via AIM to walt0023 Send a message via Yahoo to walt0023
The ZC Motor
where do you think would be the best place to buy a good runnning zc motor, i want one that i don't have to rebuild. and what are some pros and cons of the ZC. also i'm pretty sure it does but will a sohc turbo kit on the zc motor??
Old 01-17-2003, 08:44 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
yes a 92-95 civic turbo kit fits with slight modding to the intake and exhuast manifold port sizes, it has 130hp and 108lb ft, you can find them anywhere really, they are very common.
check out www.hmotorsonline.com i got my b16 from them good company, or i think www.nippon-motors.com or you can call your local shop should be able to get one for you.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 01-17-2003, 01:03 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
i would try wither of the places mentioned above. they are both in cali
you can also fit the junkyard style turbo to a ZC.
http://www.thedropshop.com/vafc.htm
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 01-17-2003, 01:29 PM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
Thumbs up
ditto - what they said ..heard good things about both companies.
Even if you don't plan to rebuild...you should at least plan on a new timing belt, water pump and plug wires. who knows how long these engines have been sitting..it is much easier to replace most of these parts when the engine is OUT of the car ;-)
Timing Belt - 88 Prelude 2.0 Si
Water Pump - 88-91 Civic/CRX Si
Plug wires - 89 Integra
HTH -
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 01-17-2003, 04:02 PM
how much do you think shipping would run on the zc?
Old 01-17-2003, 04:30 PM
amy@af's Avatar
it was $200 to have my y8 shipped from Ohio to Oregon. i couldn't imagine it being too much more
Old 01-17-2003, 04:49 PM
700 for a zc shipped with start up warrenty is good right?
Old 01-18-2003, 12:27 PM
amy@af's Avatar
if it's being shipped from CA, then yes thats not bad. the place's reputation is what really makes it worth it or not.
Does the motor have to lift to replace the oil pan gasket? wonderwalker91302 Crown Victoria 3 12-04-2006 11:41 PM
someone told me the rx7 and the Fiero are the same other then the motor Faze2183 RX-7 15 05-13-2004 01:39 AM
How do you remove the wiper arm to get to the motor? jberenyi Caravan | Voyager 1 01-09-2004 12:46 AM
What are the web sites where i can see dumb was people fu@K the motors up?? jeffseby COMPLETELY off-topic 6 08-23-2003 03:28 AM
Are the motor mounts on a 2000 Civic Si the same as 98-01 GSR? shortdahri Engineering/ Technical 2 03-21-2002 02:08 AM
