Old 01-16-2003, 06:22 PM
sprcvc82 sprcvc82 is offline
tamiya paints
I just got some tamiya paints, has anyone had good luck with airbrushing them. I airbrushed my skyline interior but it came out looking like crap. Do any of you have any suggestions, i did thin it down but it did not help alot. please help
Old 01-16-2003, 06:25 PM
freakray freakray is offline
AF Modelrater
What did you thin it down with?
I have found that the best thing to thin Tamiya paints with is Tamiya thinners and using them have yet to get a bad paint job out the airbrush.
Ray
AF User Guidelines
Old 01-16-2003, 06:32 PM
935k3's Avatar
935k3 935k3 is offline
If you are talking about the Acrylics they are wonderful paints. They do need higher pressure than some other paints to atomize well,at least 25PSI. They can easily be stripped with ammonia or window cleaner. The flats are a dream to use and you can clean the airbrush with water. I have never had any problems with them. I usually use Isopropyl Alcohol to thin them at about 25% thinner 75% paint.
Old 01-16-2003, 06:43 PM
i used just some thinner, i have thined down model master and that came out perfect on thecar,but i just got the tamiya in and it did not work as well. do you think that i need to thin it down more
Old 01-16-2003, 06:51 PM
AF Modelrater
just some thinner?
Do you mean like enamel thinner?
If you have acryllic paint you can't use enamel thinner, if you did, that is why your paint turned out awful.
What type of thinner did you use?
AF User Guidelines
Old 01-16-2003, 06:57 PM
i am at work will check when i get home. thanks for the insite.
Old 01-16-2003, 06:59 PM
BWheel BWheel is offline
You can use just about any thinner with the Tamiya Enamel paints, but ONLY use Tamiya thinners (X-20A) with their Acrylic product. You could get away with using water as a thinner, but it takes ages to dry, will run, and isn't as good as their thinner.
Where possible, you should use the Thinner from the paint manufacturer if possible, rather than some generic thinner. Can get interesting otherwise.
Old 01-16-2003, 07:43 PM
djmr2's Avatar
djmr2 djmr2 is offline
Wow, 25PSI? i've always been doing mine at around 15psi...
i usually spray things up close and thin about 50/50 though.
Old 01-16-2003, 09:48 PM
935k3's Avatar
For the Gloss colors you probably could go lower. It also depends what airbrush you are using. The really cheap single actions need allot of pressure. I have 4 airbrushes a Paasche VL a VLST-Pro and a H model. but I do most of my work with a Badger 175 Crescendo.
Laquers are good at lower pressures like 15PSI. Most manuals for airbrushes reccomend 25PSI. When I first got a gauge I did allot of experimenting and found out what works better.
Old 01-16-2003, 10:00 PM
Mr Mario's Avatar
Mr Mario Mr Mario is offline
Same here I have had some good success with a similar paint to thinner ratio usually I use less thinner. But you have to experiment with what gives you.... the results you like.
zero paints on tamiya paints? gordonli1 Car Modeling 26 04-16-2015 09:46 PM
Paints compatible with Tamiya paints? bikouros Car Modeling 7 06-17-2006 06:14 PM
SPRAY: testors paint v.s tamiya paint? integra818 Car Modeling 16 11-16-2002 01:26 PM
Painting Models using Tamiya Paint GTRRR Car Modeling 3 08-25-2002 05:41 AM
Pls who can help with Tamiya paint awaken1973 Car Modeling 0 01-12-2002 12:52 AM
