Old 03-29-2009, 06:50 AM
gordonli1 gordonli1 is offline
zero paints on tamiya paints?
Hi,
I am a newbie to modelling, done some extensive research on the two paints as memtioned above, however, I am still not sure whether the 'mix' will work.
I am planning on painting a tamiya x-1 gloss black layer, with the intension of spraying a layer of silver zero paint on top of that plus masking, to create 2 black racing strip lines in a silver body, will the zero paint eats into the tamiya paint or am I in the clear?
any help will be great
gordon
Old 03-29-2009, 08:33 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Re: zero paints on tamiya paints?
Welcome to AF, and to the hobby!!
It depends which Tamiya paint. Tamiya makes three different varieties- alcrylic, enamel, and spray lacquer. If you use Zero over the spray lacquer, you may get away with it. But do not try it over acrylic or enamel- the Zero will destroy them.
If what you want is black stripes on silver, an easier way is to use black decal film. You simply cut it to the shape you want, and apply it just like a kit decal- dip in water for a few minutes and slide in place. This way you only have to paint one color, and you don't have to mess with masking.
What are you building?
PHOTOBUCKET SUCKS
Old 03-29-2009, 06:51 PM
Thanks for the reply, The tamiya paint i was about to purchase is the X-1 gloss black, acrylic based.
I am about to start my Revell 1966 Mustang GT-350R, converting it to the gone in 60seconds 'eleanor' version, that car has always been one of my fav. It was really hard to find the GT-350R, its becoming rare in the uk, the GT-350H is more common but a lot of work is need to get the front bumper looking right with enough space for the 2nd set of head lights.
Thanks for the info. now i need to find black decal films, prob eaby
Old 03-29-2009, 08:59 PM
klutz_100's Avatar
A newbie with an airbrush - cool!
1. Put the black over the silver, not the other way round IMHO
2. Get Zero Jet Black for the stripes.
Old 03-29-2009, 09:16 PM
Do you think using alcad metallic paints for the eleanor will achieve a better result over zero paints? as the original 1:1 eleanor had a metallic shine (pewter) to it
http://www.seriouswheels.com/1960-19...t-1280x960.htm
http://www.seriouswheels.com/1960-19...2-1024x768.htm
Old 03-30-2009, 12:03 AM
Twowheelsrule Twowheelsrule is offline
Alclad rubs off of lacquer based paints easily. Testors enamel or Alclad enamel black works the best. Remember, the smoother the base paint is the better the Alclad will be.
TW
Old 03-30-2009, 01:18 AM
klutz_100's Avatar
Looks to me as if Tamiya Gunmetal would be closer than any Alclad paint.
Alclads are mostly NMF and are meant to look like real metal, not decorative metallic paints.
If you can find a paint code for the color used on the Eleanor car, Hiroboy can probably mix you up the exact color (but YOU need to provide the color code)
There have been soem very good Eleanor builds here on AF. Searching the WIP and Completed sections should bring them up. Maybe there are some useful color guides in them.
Old 03-30-2009, 12:27 PM
Hey appreantly all tamiya X-10 (gunmetal) acrylics paints been withdrawn from the uk, so having a real hardtime finding tamiya gunmetal.
But i did manage to find the colour code for the eleanor, Paint: Pepper Grey Metallic, Dupont Fleet 44490 (body). the site also memtion the metallic black strip, but is that other brand of metallic black strip which its good and can paint on top of the zero paints?
cos using the zero paint jet black doesnt give that quality but at the same time, i dont wanna fork out the extras just for a pair of black racing strips.
will speak to hiroboy about the pepper grey metallic.
Old 03-30-2009, 01:07 PM
Didymus Didymus is offline
Test it on scrap, but I 'ave me doubts.
Zero paints are urethanes and are thinned by a reducer that very much resembles lacquer thinner. Tamiya bottle paints are water-based acrylics. It's my guess that the reducer in the Zero will dissolve the acrylic undercoat and make a big mess.
I think your safest bet is to use Zero for the black coat. If you're set up for urethanes anyway, why not? It's great paint that produces a harder finish than Tamiya acrylic.
Ddms
Old 03-30-2009, 02:17 PM
actucally, instead of tamiya XF-10gun metal, i have found tamiya XF-56 metallic grey which looks really close to the actucal eleanor colour that i want at a fraction of the cost, £1.25 compared to £5.58 or somthing.
so will be spraying the tamiya XF-56. but how do i achieve the metallic look? do i simply add metal files to it?
and i am eager to know which will look better in the end, the tamiya XF-56 or the zero paint...
Old 03-30-2009, 02:28 PM
klutz_100's Avatar
It's not easy getting good results by trying to save a few Euros.
With XF 56 you are more or less putting yourself back at square one
It's a water based acrylic jar paint. Yes, you can put it OVER Zero paint. YES, you will need to put a clear coat over it. YES, you will need to be careful what clear you use since you would be putting it over the XF56 - I would recommend Mr Top Coat aerosol (Blue can) in that case.
Tamiya also have a TS series Metallic Black IIRC. You could also use this (straight from the can or, as I would suggest, decanted and put through your airbrush for better control).
Whatever you decide - good luck!
Old 03-30-2009, 02:38 PM
So many options!....hmm will need to seriously think about it...weighting out the pros and cons of each paints......
i think i will experiment with the paints, ie, getting both the tamiya XF-56 and zero paints and take it from there...modelling isnt a 'cheap' hobby any more
will keep you guys updated!
Old 03-30-2009, 02:55 PM
klutz_100's Avatar
You are over-complicating things in my opinion
Less thinking and more "doing" will bring you better results. There is no better teacher than practical experience in modelling.
BTW what were you using your airbrush for before you started modelling?
Old 03-30-2009, 02:59 PM
i havnt used an air brush before hence the dilemma i am facing.
used spray can before to spray paint 1:10 rc cars.
Old 03-30-2009, 03:04 PM
klutz_100's Avatar
So why are you considering Zero paints!?!? They need an airbrush for use unless I have missed something along the way..
