Old 06-15-2006, 09:08 PM
bikouros's Avatar
bikouros bikouros is offline
Paints compatible with Tamiya paints?
Hi
I need a Paint companys primer thats compatible with tamiya rattle cans. For some reason the hobby shop by me doesint sell the Tamiya brand primers. Thanks a lot!
Old 06-15-2006, 09:10 PM
freakray freakray is offline
AF Modelrater
Re: Paints compatible with Tamiya paints?
Zinser.
Duplicolor.
AF User Guidelines
Old 06-15-2006, 09:16 PM
freakmech's Avatar
freakmech freakmech is offline
Send a message via AIM to freakmech
If they can get the paint they can order the primer, just ask...
Friends dont let friends buy die-casts...
"If it can't run 24hrs., it aint sh!t...." -me
Old 06-15-2006, 10:27 PM
Okiemodelbuilder Okiemodelbuilder is offline
Just have your LHS order you some. You won't regret it. It's all I use...aren't your models worth the best?
Completed Pro Touring Projects
...the pro touring experts
Old 06-16-2006, 05:05 AM
cyberkid's Avatar
cyberkid cyberkid is offline
I use Gunze's Mr. Surfacer 500/1200 grit (both grey) and if I need a white base I spray TS-26 or whatever TS-white that is handy. I like to use Mr. Surfacer because it is a sandable primer. Just give the primer enough time to cure before you paint your color (that goes for all brand of paint).
Strangely though, I tried mixing TS-29 into some Mr. Surfacer to darken the paint a while ago... didn't work... looked like grounded pepper in some wierd grey soup so... don't do it lol.
Old 06-16-2006, 10:58 AM
bhop73's Avatar
bhop73 bhop73 is offline
I have used many different primers with Tamiya paints with no ill-effects. Usually I use Model Master white primer since it's relatively cheap. I've actually had better results with it than Tamiya primer. It goes on smoother.
http://www.bhop73.com/
Old 06-16-2006, 11:14 AM
gasman03's Avatar
gasman03 gasman03 is offline
I've used Model Masters new laquer white primer and it pretty good. dries fast and sands nicely. work well with Tamiya laquers
Old 06-17-2006, 06:14 PM
bikouros's Avatar
okay, thanks for the tips guys!
