Old 11-27-2002, 05:38 PM
onetrueshyguy onetrueshyguy is offline
Help! weird buzz when acclering
okay here is the problem..everytime i step on the gas pedal there would this is really faint (almost can't hear it when you roll down the windows) buzz..like the sound a computer makes...it's worrying me i was jus wondering what i should do..any ideas?
btw i own a 90 civic hb si
Old 11-27-2002, 05:41 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Its probably from the speakers or the stereo. You need a noise filter.
Old 11-27-2002, 05:43 PM
no my radio is broken and that buzz only sounds when i step on the gas pedal
could it be the fuel injectors needs cleaning or the spark plugs need replacing?
Old 11-27-2002, 11:45 PM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
Any chance it could be a Alternator Wine ????
just a thought.
||JEFF| |
Candy Orange 1990 Honda Civic H/B
Old 11-27-2002, 11:51 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Noise filter huh? My stupid passenger side speaker rattles or some crap and I know it has no filter thing on it. Does that screen really take that much sound out?
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 11-28-2002, 12:53 AM
hmm Alternator wine? i suppose you mean wire?
i thought the alternator only deals with the battery and not accleration?
Old 11-28-2002, 02:46 AM
91civicDXdude's Avatar
does it make the noise when you rev the engine in park or neutral or just while accelerating?
nope not in N or revving
Old 11-28-2002, 03:10 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
no he means alternator whinning because your alt is spinning. maybe its your ac or power steering. try and check your alt, power steering, and ac. because these all spin with bearings, so you should check it out
Old 11-28-2002, 03:12 AM
it cant be power steering but ac..as in air condition? i dont think theres a prob with that
so what do i do now ..replace the alternator?
Old 11-28-2002, 04:35 AM
you dont need to replace your alternator unless its bad. ac as in air conditioning, like the compressor. is your car an auto or a manual ?
also did this noise just start or is this the first time you have noticed it ?
and why cant it be the power steering ? you need to pop your hood and try and listen and find out where the sound it coming from. we cant really tell you what to do, we just make suggestions on what it could be. you need to find out where the sound is coming from.
Old 11-28-2002, 06:17 AM
i didn't turn on the ac so it shouldn't be the ac
it is a civic hb si 90 standard
well i just got the car and it's first time noticing it after driving a couple of times so im assuming it was there already but never really heard it
it can't be power steering b/c the car doesn't have power steering
i dont think it's hearable when im revving or acclering in N it only does the "computer whizzing" when i acclering
Old 11-28-2002, 09:43 AM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
almost like a ticking sound coming from under the dash at idle and then increasing as you accelerate? mine does that too and I'm still trying to work it out.
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 11-28-2002, 08:12 PM
yea sorta but it doesnt sound unless i acclerinate
Old 11-28-2002, 11:20 PM
hybridsol's Avatar
hybridsol hybridsol is offline
Send a message via AIM to hybridsol
Re: Help! weird buzz when acclering
Ive seen this on a few 4gs If you're lucky you may just have a loose heat shield on the exhaust or even just a loose muffler clamp. Or you may be a victim of the infamous Honda "A-pipe" rattle It seems that many Honda exhaust systems have a double pipe near the engine, with an inner and outer tube. This is in the interest of keeping the exhaust gasses heated for the catalyic converter. Unfortunately the welds on the inside don't always hold, and you can get a loose inner pipe rattling at certain times when the engine speed matches its natural point of resonance. To fix it you could replace the pipe assembly, but that's expensive. A cheaper way is to simply cut two slots crosswise about a quarter inch apart, 1/3 of the way through the outer pipe. Then with a punch, ding the narrow strip thus created inward until it touches the inner pipe. Fill the hole with brazing metal, making sure some of it brazes the strip to the inner pipe. Make sure you don't leave any holes that will leak exhaust gasses. (it actually could be numerous things, but this is common)
One speaker buzzing when turned on, others are fine Destrozado Car Audio 3 09-02-2010 09:35 PM
91 tracker has miss when acclerating versatech Tracker 2 07-10-2008 02:17 PM
Sputter when acclerating too fast. seldomo19 Park Avenue 1 11-24-2005 05:15 PM
vibration from front end when acclerating dan619 Altima 1 08-29-2005 07:48 PM
Help! weird buzz when acclering onetrueshyguy Engineering/ Technical 28 12-10-2002 06:07 PM
