Old 08-31-2010, 04:57 PM
Destrozado Destrozado is offline
One speaker buzzing when turned on, others are fine
My rear deck speakers were going out so I got some new ones about 2 months ago and installed them - Sony 6 1/2. The left rear was then fine, but the right rear was still cracking a bit. I had also been having some trouble with the head unit (old Pioneer) so I got a new head unit (Sony Xplode) and just installed that. Now, the right rear speaker works fine, but the left rear speaker, which was fine before, will buzz or hum for about 10 seconds on start up, then no sound at all from that speaker. I start the car, the left rear speaker buzzes for about 5-10 seconds while the other speakers do nothing, then the left rear speaker stops buzzing and the right rear and front speakers start playing music. The head unit displays "failure" which the manual says indicates that there is something wrong with the speaker wiring or connection. I thought maybe the wires needed to be replaced before this, but I didn't do anything with the wires and the right one didn't work before the head unit but the left did, and now after changing the head unit, the right one works and the left doesn't. What gives?
Old 08-31-2010, 08:49 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: One speaker buzzing when turned on, others are fine
sounds like the bad speaker has been grouded out to the frame somehow. Do you have another speaker you can connect up to that wire ?
Old 09-01-2010, 06:31 AM
Well last night after posting I pulled the wire off the speaker not working and put it on the right speaker. I had the volume turned down really low, so that I had to be right there to here it. It worked fine through that speaker. Then, I put it back on the "bad" speaker and it also worked fine. Then I connected the right speaker again and both were working fine. Then I turned the music up and the left speaker stopped working again. This time I left the music up higher, moved the wire from the left to the right speaker, and it did not work on the right speaker either. So does that mean it is the wire? I don't understand why it would work at low volume though...
Old 09-02-2010, 09:35 PM
Audio Guy
then you have either grounded out the speaker wire somewhere or the amp in cd player is bad.
2004 Flashers turn on when turn on Left turn signal n2racing Silverado 0 04-11-2009 09:23 AM
reverse lights dont come on. bulbs are fine austin881 Problem Diagnosis 1 03-08-2007 09:25 PM
Humming nose when turning on the a/c on 98 Dodge Minivan R_Lalau Ram Van 0 05-29-2006 08:06 AM
95 Aurora just buzzes when turning the key? unioncreek Aurora 3 08-30-2005 08:33 AM
speakers buzz when cassette plays rrgarmy Cavalier Problem Diagnosis 2 05-17-2005 07:26 PM
Tags
audio , buzzing , sony , speakers
