Old 09-24-2007, 07:41 AM
KP60's Avatar
KP60 KP60 is offline
Hello again, I'm back after a looong time, and I'm building a lot of models at the same time...
This is the Revell Ford Escort Rally (MKii)
and instead of rally version I'm going for the drift scene...
I dont have much free time, so be patient..
well this body needs a LOT of work...
(sorry for bad picture focus)..
Old 09-25-2007, 02:54 AM
KP60's Avatar
Re: WIP: Revell Escort MKii -drift-
after some cutting, scratching, and a lot of sanding...
first coat of paint (Tamiya pure white spray)
added some putty
I'm going for white body, CF hood, gold wheels and some weathering...
what u think???
Old 09-26-2007, 02:37 AM
KP60's Avatar
painted the wheels gold:
put together the engine, and painted it (but it turned out too shiny ):
second hand painted the body:
test fitting wheels and hood:
what do you think?????
test fitting the engine:
painted the engine (again):
painted wheel bolts:
I tried to glue some soark plugs... but it ended up a disaster..
I glued them on, with cyanacrylic cement, and sfter a while they went off (!!!)
I guess I shouldn't glue them on top of the paint.. RIGHT???
SOME HELP HERE PLEASE
should I scratch the paint and glue them on the plastic???
(what material do you use for cables??? -these are real (very thin) cables..)
I also sprayed another coat of white on the body (but I screwed this one also!!) I sprayed too much paint.........
now I have to sand it and paint it again........
Old 09-26-2007, 03:45 PM
rallymaster's Avatar
Didn't you use primer ??
that could be the answer to your paint problem, because paint will easyly cover primer than plastic and putty.
Phil
Old 09-27-2007, 02:17 AM
KP60's Avatar
no, I didnt, and I think youre absolutely right..
can I use primer now??
(if I sand it first...)
Old 09-27-2007, 03:18 AM
Mr. Me.'s Avatar
Mr. Me. Mr. Me. is offline
Send a message via ICQ to Mr. Me.
hm.. take off the whole pain, then primer it grey, white and then paint it..
Old 09-12-2008, 05:42 AM
KP60's Avatar
Well, I sanded off the paint and sprayed the boby with primer.
Then I painted it white.
I also painted the interior white.
Old 09-12-2008, 05:48 AM
KP60's Avatar
This is a drift version and is going to be "used" with scratches, dirt, and stuff.
Maybe I will also use it in a diorama!
Here are some exterior progress pics.
and some engine wiring..
Old 09-13-2008, 05:55 AM
Alexander DeLarge's Avatar
Alexander DeLarge Alexander DeLarge is offline
Looks like the guy doesn't know where "this car part" belongs...
Old 09-13-2008, 06:29 AM
nomad_fsoak nomad_fsoak is offline
depending on diameter i use either cables , or just copper wires (from the inside of cables)
Take a look at my Lancer interior:
"safety foams" are made from cable insulation, and are mounted with one of wires from inside of cable
also the e-brake hose is made of cable insulation (but not cutted along, just took the wires out from inside)
You should have masked those door panels out to paint them black or sth dark - they don't look good in white.
Old 10-23-2008, 11:54 AM
Fabio Quirino's Avatar
Fabio Quirino Fabio Quirino is offline
Nice, a different look !
www.instagram.com/modelkits.rj
