Old 11-05-2002, 08:32 AM
Menace003 Menace003 is offline
Send a message via AIM to Menace003
Question SOHC Vtec Question
Hey whats up all, I was just wondering if anyone has the d16z6 swap in their 4g civic? And if so did you use all the parts off the SOHC Vtec motor like Intake manifold, tranny, and ECU...???? I am going to be performing this swap in a afew months so I want to gather as much info as possible considering I'm doing it myself with a friend of mine. Thanks for all your help and input.
Jon
'91 Civic DX hatch
Stock for right now
Looking for intake
Old 11-05-2002, 08:52 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
http://www.automotiveforums.com/vbul...ight=sohc+vtec
check out these threads...
SOLD!
Old 11-05-2002, 06:03 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
I'm going to be doing the D16y8 swap soon, which is almost identical to the z6 engine, but here's what I've learned so far:
Yep, you should be able to use all that stuff... P28 ECU, and you'll have to wire up for OBD1. Everything else should work, you'll need to get a VTEC controller or an RPM activated switch for the VTEC.
As far as the tranny goes, I would stick with a 4G Si tranny or a ZC tranny with an Si final drive.
I would also recommend purchasing a wiring harness from dropshop (www.thedropshop.tv). They cost $150 I think, but I hear it's very worthwhile, unless you wanna spend all your time cutting and splicing wiring...
Old 11-05-2002, 09:33 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
I have the z6 in my hatch, i used everything from it.I however cut off and soldered all 50 or so wires from the ECU. If i had to do it again i would definetly use that plug and play wire harness from dropshop. $150 is SO cheap compared to the time i spent re-wiring the whole ECU...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 11-06-2002, 08:10 AM
91civicDXdude's Avatar
the p28 ecu has a stock VTEC activation point. if you're going through the trouble of using the p28 ecu, you might as well use it to activate VTEC since it will change your fuel and ignition curves as well to compensate for the different cam lobes.
Old 11-06-2002, 01:11 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
check out the engine section of the 4tg gen site. there are a bunch of swap info links.
i have the y8. it is currently hooked up through rpm switch. the ecu route is MUCH better :flash:
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
anyone have any info on a f22a non-vtec head swap to a f22b sohc vtec head mox4_2001 Let's get Technical! 3 06-27-2004 07:46 PM
SOHC hands SOHC VTEC its... SilverY2KCivic Street Racing 21 01-22-2004 03:18 PM
Sohc Vtec head 2 A Non Vtec Block lowcivicman99 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 06-25-2002 06:31 PM
Sohc Vtec head 2 A Non Vtec Block lowcivicman99 '71-'87 Civic | CRX 1 06-24-2002 11:43 PM
Port & Polish on SOHC VTEC... gains? sparq Engineering/ Technical 5 02-02-2002 11:30 PM
