Old 11-03-2002, 02:35 PM
mylittedaisy mylittedaisy is offline
Timing belt
I have 85,000 miles on my car, and I was wondering when I should change my timing belt. And if I should change anything else while I'm at it?
Old 11-03-2002, 04:51 PM
5genhbtrubo15 5genhbtrubo15 is offline
Lightbulb timing belt
you need your timing belt and water pump replaced at 96000mi acording to handa but i would go ahead and do it when you get a chance see ya :frog: :frog:
Old 11-03-2002, 08:49 PM
thewoahna's Avatar
thewoahna thewoahna is offline
Send a message via AIM to thewoahna
Yeah, I would do it now. You should also have the water pump replaced as well (like 5genhbtrubo15 said). I would also replace the radiator hose, other belts (if needed), and have the ball joints checked.
Whenever at a loss of words, "Woah Na!" will suffice....
AOL IM: WoahNa316
Click here for some of my car pics/stats
Old 11-03-2002, 09:38 PM
yougod10 yougod10 is offline
Send a message via AIM to yougod10
Honda 90k:
1. Change engine oil fiter and oil
2. Lube hinges latches
3. Underbody inspection
4. Check all belts, hoses, and fluid levels
5. Rotate and balance front 2 tires
6. Clean and adjust rear drum brakes (if applicable)
7. Adjust valves to manu. specs
8. Replace timing belt
10.Replace air filter
11.Replace HVAC filter
12.Replace distributor cap
-I might've missed a couple things bcuz I didnt memorize whats in the book
-Keep in mind that after adjusting valves, your car will sound louder because valves wear tight (not loose). Best time do replace water pump is when you replace your timing belt.
www.nexusmotorsports.net
Old 11-17-2002, 09:51 AM
crabguts00 crabguts00 is offline
Timing belt
Hey everyone I have a 2000 HX civic when do I have to change the timing belt. I read the book it says 60,000 miles is that true? I heard I thought someone said 90,000 thanks
steve
email [email protected]
Old 11-17-2002, 01:13 PM
The Honda service books say 90k but some of the ones that use 5w20 have a different service cycle. But I don't think it would be less than 90k since the services go up from 3,750 to 5,000 mile services. 90k is recommended on most and thats what I thnk u should go by.
Old 11-22-2002, 11:14 AM
RoBoDEATH RoBoDEATH is offline
Send a message via AIM to RoBoDEATH Send a message via Yahoo to RoBoDEATH
i do it every 70k, dont want that mofo to break
1998 Honda Civic EX--Si Wing--Jackson Racing Supercharger--Enkei RP07 18inch Rims--Yokohama PARADA 215/35ZR/18's--K&N Filter--Hurst ShortShifter--DC Sport Header--Greddy Cat-Back Exhaust--DC Strut Tie Bar--Eibach Springs with Ground Control Coil Overs--Ingalls Rear Camber Kit Arms--Skunk2 Front Camber Kits--Panasonic DF88 CD Player--Two 1Fared Caps--Sony Xplod 800W Amp--SPL Series II 1200W Amp--Solo Baric 15--!!!!!SOLD!!!!!!!
2001 Honda S2000 NFR--HKS Hi-Power Duel Exhaust--NRG Hood Dampers
Old 08-11-2003, 10:50 AM
Hey guys I finally called 2 local honda shops they say if you have a 99 civic yu have to change it like around 90thousand and the 00 like mine is reccomend ant 105thousand. Thanks
steve
Old 08-11-2003, 10:42 PM
BullShifter's Avatar
yougod10 why would you only rotate & balance 2 tires if you have all 4 off that sounds stupid!
Some Honda's recommend 60K & others @ 90K. I would go no more that 80K myself. Honda 90K does not include t/belt replacement
Timing belt replacement is not cheap unless you can do it yourself. Other wise 60K & 90K service w/ timing belt will run around $1,000 @ the dealer. You can do just the minimun : t/belt, water pump, assy belts. I would have the valves adjusted also if not done in the last 15K
Old 08-12-2003, 07:46 AM
DelSolSI-96 DelSolSI-96 is offline
Send a message via AIM to DelSolSI-96
How about any seals or tenioner or caskets because i will also be doing this this weekend.
Got Sol?
Old 12-18-2003, 07:03 PM
number1stunnar22 number1stunnar22 is offline
Re: Timing belt
i need timing diagram and specs for an 1987 interga
2000 Mirage 1.8 Timing Belt changeout Mangoacn Mirage 0 12-18-2009 08:51 PM
Timing belt walk HELP! 91TSi_ Engine, Transmission and Drivetrain 13 10-15-2009 02:47 PM
Timing Belt kp055174 Accord/TSX/Accord Hybrid 2 07-27-2009 12:00 PM
timing belt and water pump :( cobraprince 3000GT/Stealth 17 07-09-2009 03:28 AM
How to change timing belt? RainSpirit44 SVX 2 03-25-2009 04:30 AM
