Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 10-26-2002, 07:55 PM
MattyO217 MattyO217 is offline
What's the difference in the real world?
How much of a difference is there between an 11 lb 15x7 wheel with 195/55 15 tires and a 17 lb 16x7 wheel with 205/45 16 tires? Handling and acceleration/braking/responsiveness, ride, etc.?
Thanks.
btw - I know the theories of lighter, wider wheels and lower profile tires, but I don't know how much of an actual difference say 6 lbs and a little lower profile tire would make in the real world when put on a 160 (flywheel) Civic Si. I also plan on doing F.I. (ie JRS).
Old 10-28-2002, 06:52 AM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
I went from a 17lb 16x7" Konig Burners with 215/40x16" Kumho 712s to a 14lb 16x7.5" Kosei K1 with 215/40x16" Kumho 712s and the difference was noticeable. Car accelerated quicker and suspenion was able to work quicker due to the lighter weight. I'm now using a 13lb Kosei K1 and response is even better.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 10-29-2002, 03:27 PM
dome's Avatar
dome dome is offline
I just took off my 15s with 195/55s and put on my steelies, and I could tell a difference with that. I mean it is only a marginal change in size, width and weight but the difference is apparent (at least to me).
I think you'll definitely feel a difference between a 17lb 16 and 11lb 15. Not only in the weight, but with the added comfort a thicker sidewall will provide.
TDC #718
Old 10-31-2002, 04:35 PM
philbra philbra is offline
As my friend Josh says.... "rolling resistance is everything". But in a real-world scenario, it's a give and take proposition. You gain some better response on take-off via the lower profile (and more if you go from steel to aluminum) and also better handling, but you lose some of the confort of the thicker sidewall as stated earlier.
Also, the low-pro tire/wheel combo will help in day-to-driving from my experience. Just run a few tests and swaps and see if the diff comes through. Less flex from a sidewall and a wider (perhaps better?) tread will increase overall stopping and handling. Not by much on paper, but an extra foot comes in handy on the road.
Hope this helps.
Old 11-12-2002, 02:04 PM
I just want to say thanks guys for your responses. That helps. I'll probably go with the 15's. They're the Axis mag-lite's 15x7. Was thinking of pairing them with 205/50 15 Kuhmo 712's. Any opinions on the wheel/tire/brands/size/etc?
Thanks again,
M
:flash:
Old 11-13-2002, 06:48 AM
Civic Mod
Well what are you going ot use the setup for? Autocross? Daily driver? Road racing?
Autocross Help Page
Buy my Civic parts!
Old 11-13-2002, 02:00 PM
Daily driver. I want to make it perform as good as it can with what I do to it though. I don't mind occaisionally lining up at stoplights (and I want the best chance at winning -- who wants to lose?), but I don't have plans right now to take it to the track. I am also a perfectionist. I want my car to be just right for me in many respects (performance, looks, ride, responsiveness, braking, etc. ...who doesn't?)
~M
:smoka:
Old 11-14-2002, 06:38 AM
Civic Mod
The best affordable tire is the Falken Azenis. For $60-70 a tire you get almost the same performance as some DOT racing tires. I'm running 205/50x15" Azenis with Kosei K1s (15x7") which weigh about 13-14lbs. Those cost about $125-150 each.
And please don't street race, it's dumb, stupid, and just plain immature.
Autocross Help Page
Buy my Civic parts!
Old 11-14-2002, 09:19 AM
Thanks, I appreciate all your advice. You seem very knowledgable (please excuse any of my spelling errors).
~M
Old 11-15-2002, 06:37 AM
Civic Mod
~M
I'm just trying to be helpful. And to think 6 years ago I didn't even know how to change my oil
Autocross Help Page
Buy my Civic parts!
Old 11-17-2002, 03:18 PM
Going from a 40 series (you said you had 215/40 16's) tire to a 50 series tire (205/50 15's) did you notice any DECREASED responsiveness? I know you said response is better, but was that just due to the lighter weight (i.e. made acceleration, braking, and maybe grip better)? I guess what I'm thinking is wouldn't you lose some turn-in responsiveness (like maybe a little mushier when abruptly turning due to the slightly thicker (50 series) sidewall)? Maybe I'm wrong. Does it matter if it's say, a 50 (i.e. 205/50 15) series Z rated tire vs. a 45 series Z rated tire(i.e. 205/45 16)? I guess I just want to make sure I'm making the right choice for my taste in performance. I want my car to be responsive as possible. I'm probably nit picking but just want to be sure.
Thanks for you help,
~M
Old 11-18-2002, 06:41 AM
Civic Mod
~M
Well the biggest thing was the tires. The Azenis in 215/40x16" weighed about 40lbs on 16x7.5" wheels. PLus those tires rubbed like crazy! They were more like 225/40x16" or even 235/40x16". The 205/50x15" on 15x7" Kosei K1s weighed 32lbs. But those are more like 215/50x15" or close to 225/50x15" Very wide tires.
But yeah braking, accelerating, and turning improved going from the 16s to the 15s and turn in didn't really change either. PLus there are more "high performance" tires in 15s than 16s.
I also feel safer driving on the streets with 15s than 16s. Having a larger sidewall helps cushion the ride, and protect from potholes better.
Autocross Help Page
Buy my Civic parts!
Old 12-10-2002, 10:31 AM
I just got done talking to a guy at Wheelmax. He said to go with 17's if I plan on modding my car to 200-300 hp. I am still unsure about what size wheels to go with! I don't trust salesmen too much. I'd think there'd still be a substantial (spelling?) performance gain even with a turbo/supercharger set up (on a 1999 Si) with light weight 15's (11.5 lbs) vs heavier 17's (18-22.5 lbs depending on which 17 I'd go with). I'd imagine that breaking distance would be increased with the 17's, along with slower ET's, harsher ride quality, but better responsiveness (turn in, salom, etc.), and possibly better grip (ie would do better on skidpad test) due to the stiffer sidewalls' higher resistance to rolling over (am I right?). But I read a SCC book that did a test between different sized wheels and tires. The 205/40 17's had a shorter stopping distance than 205/50 15's (by about a whole one foot! heheh. but none the less...it's still a heavier wheel). The tires I'd get (Kuhmo 712 or Sumitomo HTRZ II) would be 205/50 15 V (possibly W) verses 205/40 17 W or Z speed rating. I like the looks of the 17's, the 15's aren't bad, but I don't want to give up much performance. How much performance would I lose by going with the 17's and what other advantages would I gain besides appearance (i.e. responsiveness, grip in cornering, etc?). Also what about the heavier wheels and the drive shafts, etc? How much hp can the stock parts handle?
Thanks for all the help,
~M
Old 12-10-2002, 08:51 PM
Civic Mod
~M
The worse people to ask what size to get are places that sell them. Of course he wants you to get 17s. 17s are more expensive, more prone to pothole damages, and tires cost more.
I'd say stick with a 15-16" wheel if you are going to get a package. But on the other note modding your car to 200-300hp is a bit expensive. I think you should first prioritize. Not know what you are doing in the first place and you could waste $$$ like I did
Autocross Help Page
Buy my Civic parts!
Old 12-17-2002, 08:46 AM
Thanks for your responses.:alien:
My next question is somewhat technical. What would give better traction: 205/50 15 11.5 lb wheel or a 205/40-17 17 lb wheel? It's technical because I'm compairing the decreased weight to the increased contact patch. I don't know if this can be accurately answered. I would think that how much horsepower I plan on making would come into play here. I say that because as you increase hp, traction becomes a bigger issue and I'd think that in straight line acceleration, the increased contact patch would be better. But as for cornering, what would give more grip, all things equal except for wheel weight and tire size? A wheel that's 5.5 lbs lighter with a slightly smaller contact patch or a wheel that's 5.5 lbs heavier with a slightly larger contact patch due to a lower aspect ratio??
Thanks for the help,
M
:smoka:
What's the difference between the 4cyl engines in the Accord? rraven Engineering/ Technical 4 03-19-2003 09:59 PM
the real world sportsfan Nissan 350Z/370Z | Infiniti G35/G37 Coupe 1 08-03-2002 08:08 AM
what's the difference between rps13 and the ps13???? bamer02 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 2 05-09-2002 08:22 PM
What's the difference between having Drop Spindles in the front and Coils? NassD General Discussion 4 04-21-2002 12:04 AM
