Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 05-09-2002, 03:00 PM
bamer02 bamer02 is offline
what's the difference between rps13 and the ps13????
what's the difference between rps13 and the ps13???? can you guys give me spec if there's a difference. thanks! BTW who did a sr20det swap to their 93 240sx?pls reply! thanks!
Old 05-09-2002, 03:19 PM
Bean Bandit's Avatar
Bean Bandit Bean Bandit is offline
I knew I read it somewhere
Originally posted by mav1178
I don't have exact dates memorized off the top of my head, but the Silvia was introduced first with the CA18DET, then the 180SX was introduced with the same engine 6 months later. In early 1991 the Silvia with SR20DET was introduced, as was the SR in the 180SX. That's why if you take a look at the chassis designations for the S13, you can find out that there was a S13, a PS13, a RS13, RPS13, etc. P stands for the SR20DE/DET engine, while the R designates a fastback body style. The S14 was introduced in 1994 in Japan, with U.S. introduction a year later.
If you use the search engine on AF you'll be surprised howmany things already have been talked about
Finaly got my RS13 now need money to mod it
Fun is not a straight line. AFs member #299, loyal european support since 02/2001.
Old 05-09-2002, 08:22 PM
J SPEC SilEighty's Avatar
J SPEC SilEighty J SPEC SilEighty is offline
Send a message via AIM to J SPEC SilEighty
I know, it's amazing how much stuff you can find in these threads if you just look
What's the difference between LS and Z-34... corning_d3 Lumina 16 08-09-2006 06:13 PM
What is the difference between HP at the wheel and HP at the crank ? EIPITL 3000GT/Stealth 3 02-11-2005 10:11 AM
What's the difference between "power" and overdrive? rion Camry/Camry Hybrid/Vista 1 10-15-2004 05:14 AM
what's the difference between catback and dual exhaust? c a m a r o Engineering/ Technical 4 12-31-2003 08:56 PM
What is the difference between boring and stroking a motor? sheemo3 Engineering/ Technical 3 09-02-2003 11:50 PM
