Old 10-23-2002, 06:04 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Homebrew Gasoline Octane Boosters
I would NOT suggest that a person use the following fuel mixtures without considering the detrimental effects on your engine, vital engine components (O2 sensor, etc), and other potential damage. That said, the information is interesting.
Formula #1 - Toluene
R+M/2.........114
Cost...........$2.50/gal
Mixtures with 92 Octane Premium
10%...........94.2 Octane
20%...........96.4 Octane
30%...........98.6 Octane
Notes: Common ingredient in Octane Boosters in a can. 12-16 ounces will only raise octane 2-3 *points*, i.e. from 92 to 92.3. Often costs $3-5 for 12-16 ounces, when it can be purchased for less than $3/gal at chemical supply houses or paint stores.
Formula #2 - Xylene
R+M/2.........117
Cost...........$2.75/gal
10%...........94.5 Octane
20%...........97.0 Octane
30%...........99.5 Octane
Notes: Similar to Toluene. 12-16 ounces will only raise octane 2-3 *points*, i.e. from 92 to 92.3. Usually mixed with Toluene and advertised as *race formula*.
Formula #3 - Methyl-tertiary-butyl-ether (MTBE)
R+M/2.........118
Cost...........$3.50/gal
10%...........94.6 Octane
20%...........97.2 Octane
30%...........99.8 Octane
Notes: Oxygenate. Very common in octane booster products. Has lower BTU content than toluene or xylene, but oxygenate effect makes the gasoline burn better and produce more energy.
Formula #4 - Methanol or Ethanol
R+M/2.........101
Cost...........$0.60 - $1.75/gal
10%...........94.3 Octane (Methanol)
10%...........94.7 Octane (Ethanol)
20%...........Not Recommended
Notes: Methanol is wood alcohol. Ethanol is grain alcohol and found in Gasohol in 10% ratios. Both alcohols are mildly corrosive and will eat gas tank linings, rubber and aluminum if used in excessive ratios. Main ingredient in "Gas Dryers", combine with water.
Formula #5 - Isopropyl Alcohol and Tertiary Butyl Alcohol
R+M/2.........101
Cost...........$0.60-$1.50/gal
30%...........Not Recommended
Notes: Similar to Methanol/Ethanol. Isopropyl Alcohol is simply rubbing alcohol.
Sample Mixture
To make your own octane booster, it is easiest to make up a large batch, and then bottle it up in "dosage-size" uses.
Below is the basic formula of one of the popular octane booster products. To make eight 16 ounce bottles (128 oz = 1 gal):
100 oz of toluene for octane boost
25 oz of mineral spirits (cleaning agent)
3 oz of transmission fluid (lubricating agent)
This product is advertised as "octane booster with cleaning agent *and* lubricating agent!". Diesel fuel or kerosene can be substituted for mineral spirits and light turbine oil can be substituted for transmission fluid. Color can be added with petroleum dyes.
Old 10-23-2002, 07:06 PM
dfarres's Avatar
dfarres dfarres is offline
Send a message via Yahoo to dfarres
That's pretty cool, I'll have to talk 2 my friend about these mixtures since he works for a refinery. Or he can just give me some stuff from the warehouse. He gave me this stuff that cleans ur fuel system & all i have to add to a fuel tank is 2 teaspoons, the gallon should go a long way.
1993 Civic Coupe EX
1997 Chevy Suburban LT
“It's all fun and games - Until someone loses an eye"
Old 10-23-2002, 10:48 PM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
I think i would be to scared to dump that into my gas tank
||JEFF| |
Candy Orange 1990 Honda Civic H/B
Old 10-24-2002, 12:28 PM
bald eagle bald eagle is offline
Thumbs up octane booooost
You know looking at the list all of them will work , but do you want to find out that you messed up on the % and have costly repairs a head of you but if your not worried about it go for it
Old 10-25-2002, 03:11 AM
Thumbs up made some tonight
we made some at work 10/24 it was ok as far as i know . we did formula # 3 the m.t.b.e. cocktail at about 15% per gallon ,, took a trip on the freeway at wide open and it was ok but im not sure if i would do it a lot .
Is 87 octane gas with octane booster as good as 93? Spectre120 Camaro Discussions 28 10-20-2004 05:51 PM
Octane Boosters and 89 or 93 octane gas blazzingbrandon 4Runner/GX470 2 08-29-2004 02:02 AM
octane booster dhamo69 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 08-02-2001 03:02 PM
Homebrew Gasoline Octane Boosters kris COMPLETELY off-topic 3 07-03-2001 06:07 PM
Octane Booster madman General Discussion 5 06-27-2001 09:38 PM
