Old 06-27-2001, 12:31 AM
kris's Avatar
kris kris is offline
Off playing with fire.
Post Homebrew Gasoline Octane Boosters
I would NOT suggest that a person use the following fuel mixtures without considering the detrimental effects on your engine, vital engine components (O2 sensor, etc), and other potential damage. That said, the information is interesting.
Formula #1 - Toluene
R+M/2.........114
Cost...........$2.50/gal
Mixtures with 92 Octane Premium
10%...........94.2 Octane
20%...........96.4 Octane
30%...........98.6 Octane
Notes: Common ingredient in Octane Boosters in a can. 12-16 ounces will only raise octane 2-3 *points*, i.e. from 92 to 92.3. Often costs $3-5 for 12-16 ounces, when it can be purchased for less than $3/gal at chemical supply houses or paint stores.
Formula #2 - Xylene
R+M/2.........117
Cost...........$2.75/gal
10%...........94.5 Octane
20%...........97.0 Octane
30%...........99.5 Octane
Notes: Similar to Toluene. 12-16 ounces will only raise octane 2-3 *points*, i.e. from 92 to 92.3. Usually mixed with Toluene and advertised as *race formula*.
Formula #3 - Methyl-tertiary-butyl-ether (MTBE)
R+M/2.........118
Cost...........$3.50/gal
10%...........94.6 Octane
20%...........97.2 Octane
30%...........99.8 Octane
Notes: Oxygenate. Very common in octane booster products. Has lower BTU content than toluene or xylene, but oxygenate effect makes the gasoline burn better and produce more energy.
Formula #4 - Methanol or Ethanol
R+M/2.........101
Cost...........$0.60 - $1.75/gal
10%...........94.3 Octane (Methanol)
10%...........94.7 Octane (Ethanol)
20%...........Not Recommended
Notes: Methanol is wood alcohol. Ethanol is grain alcohol and found in Gasohol in 10% ratios. Both alcohols are mildly corrosive and will eat gas tank linings, rubber and aluminum if used in excessive ratios. Main ingredient in "Gas Dryers", combine with water.
Formula #5 - Isopropyl Alcohol and Tertiary Butyl Alcohol
R+M/2.........101
Cost...........$0.60-$1.50/gal
30%...........Not Recommended
Notes: Similar to Methanol/Ethanol. Isopropyl Alcohol is simply rubbing alcohol.
Sample Mixture
To make your own octane booster, it is easiest to make up a large batch, and then bottle it up in "dosage-size" uses.
Below is the basic formula of one of the popular octane booster products. To make eight 16 ounce bottles (128 oz = 1 gal):
100 oz of toluene for octane boost
25 oz of mineral spirits (cleaning agent)
3 oz of transmission fluid (lubricating agent)
This product is advertised as "octane booster with cleaning agent *and* lubricating agent!". Diesel fuel or kerosene can be substituted for mineral spirits and light turbine oil can be substituted for transmission fluid. Color can be added with petroleum dyes.
Old 06-27-2001, 05:21 PM
Porsche's Avatar
Porsche Porsche is offline
Pretty much amazing
Send a message via MSN to Porsche
A lot of that went over my head, but I did like the "Not Recommended" Ones.
ec437 on grammar;
Originally Posted by ec437
I'd've
Originally Posted by 2strokebloke
Any car built by "Dr. Technology" is probably not worth $5000
Old 06-27-2001, 07:48 PM
CraigFL's Avatar
CraigFL CraigFL is offline
Those mixtures remind me of the time when my partner and I were racing Karts. We found this book about super fuel mixtures and were making homebrew stuff. If I remember, the mixtures included ethanol, MEK, tolulene, Xylene, benzine. When we used this stuff the kart would fly but the end result would either be a fouled plug or the engine seals would dissolve.
It's a wonder we're still alive with all those carcinogens...
Old 07-03-2001, 06:07 PM
matt's Avatar
matt matt is offline
A 30% mixture of MTBE sounds pretty sweet
[000000] I-6 Power
Is 87 octane gas with octane booster as good as 93? Spectre120 Camaro Discussions 28 10-20-2004 05:51 PM
Octane Boosters and 89 or 93 octane gas blazzingbrandon 4Runner/GX470 2 08-29-2004 02:02 AM
Homebrew Gasoline Octane Boosters kris '88 - '91 Civic | CRX | Wagon | Shuttlee 4 10-25-2002 03:11 AM
octane booster dhamo69 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 08-02-2001 03:02 PM
Octane Booster madman General Discussion 5 06-27-2001 09:38 PM
