Old 10-21-2002, 10:30 PM
nolesfootball96 nolesfootball96 is offline
Question help with sohc vtec swap into 96 dx
Hey guys,
I am thinking about buying a somewhat built D16Y8 engine into a 96 civic dx. The motor has a bullfrog head(p&p) and cam, str fuel rail, header, big bore throttle body, ported intake manifold, and nology wires. The seller said that this setup made 140hp at the wheels.
I am not looking to spend a lot of money in order to do a dohc swap, so I decided to go with this one. The problem is that is doesn't include the wiring harness (but does include the ecu). Can I use the existing harness from my old motor? If so, what will I have to do to make this work?
Also, I could buy an ls swap for about the same price. Would this be a better deal?
I am new to the forum, so I apologize for the newby questions.
Thanks,
Samuel
Old 10-21-2002, 10:35 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
try HASport.com, they make a kit to put a z6/y8 motor in to a 6th gen civic...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 10-22-2002, 03:54 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
if it were me, i would go ls because the ls has more potential. but if you want to know which one is faster, a stock ls or that built sohc vtec, the sohc vtec would be faster. but if you gonna turbo it later then i say go ls
Old 10-25-2002, 01:06 AM
YOUNGSTER YOUNGSTER is offline
Send a message via AIM to YOUNGSTER Send a message via MSN to YOUNGSTER Send a message via Yahoo to YOUNGSTER
i would just check out ebay or hasport maybe even placeracing for a wire harness and go with the soch v tec especaially if you your not looking to spend to much cash
Need help with an obdo ls vtec swap into my obd1 del sol mr.s2k Del Sol 1 09-21-2008 01:08 AM
Need Help With SOHC ZC Vtec!! twiztedcfx Let's get Technical! 6 06-24-2005 10:30 AM
89 Teg. LS swap vs. SOHC VTEC swap cornbread499 '88 - '91 Civic | CRX | Wagon | Shuttlee 3 06-24-2003 09:21 PM
What is needed for SOHC VTEC Swap... FourthGenHatch '88 - '91 Civic | CRX | Wagon | Shuttlee 27 09-28-2002 10:55 PM
SOHC VTEC swap pics 91civicDXdude '88 - '91 Civic | CRX | Wagon | Shuttlee 15 09-09-2002 01:15 AM
