Old 09-27-2002, 02:04 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
What is needed for SOHC VTEC Swap...
I was going to do a B16 or B18 but I don't really feel like dealing with all the mounts, linkage, axels and all that crap. So now I rather just stay D-series. Which the most powerful USDM ones would be the D16Y8 and D16Z6 I think? I really would only need the engine and everything attached to it right? I can still use my tranny? And out of the Y8 and Z6 which one is better?
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 09-27-2002, 02:08 PM
91zc 91zc is offline
Use the Y8...it is newer. You also need to convert to either OBD1 or OBD0.
91 civic 4dr
b16a
14.8@94
Old 09-27-2002, 02:10 PM
Bleebdat Bleebdat is offline
Send a message via AIM to Bleebdat Send a message via Yahoo to Bleebdat
Y8 is a little better due to higher compression and better designed intake manifold. To do the swap you should use your tranny, newer engine, your ecu, distributor, im not sure about plug wires, your axles, and somehow hook up vtec either via and rpm activator or zdyne product. The swap seems so straight forward, I will be starting on mine after I grab my engine on the 20th of oct.
Old 09-27-2002, 02:21 PM
Is there any tutorials about how to do all the wiring exactly?
Old 09-27-2002, 02:31 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
sorry Bleebdat..i have to correct you a little. you only use your parts if you have a SI..if you have a DX you will need d16a6 (si) parts. you can use a dx tranny but, if you have an extra $1-200 it is very worth it to get a better geared Si tranny.
there are 2 ways.
-use a6 ecu, distro, and rpm activated switch
-use z6/y8 parts and p28 (92-95 Si/EX) ECU. you can rewire 50 wire (i hope you have patience) or get a wire conversion harness for $150
the p28 route is much better. you can lose a couple of ponies going with the 88-91 Si ecu. i also hear you lose a little gas mileage (but i doubt much). the p28 ecu will engage vtec, no rpm switch needed. another i noticed is that with the p28 your check engine light flashes the error code rather than pulling up your carpet to read the ecu.
http://www.geocities.com/bing_bong916/vtec.html
http://hybrid2.honda-perf.org/tech/sohcvtec.html
http://www.geocities.com/kurtsi_on/page7.html
http://www.geocities.com/crx288/d16z6swap.html
http://www.angelfire.com/ca/DrOhm/hybrid.html
http://integra.vtec.net/engine/vcontrol.html
this post is exactly why i have been asking people for informational and engine source links in that other post wouldn't it be great to have all the engine/swap info at the site?
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 09-27-2002, 03:38 PM
stock1.5 stock1.5 is offline
genious.. purely genious
IM RICK JAMES BITCH
Old 09-27-2002, 07:11 PM
Ami, you are right about the dx part, I was assuming Si =].
Old 09-27-2002, 10:29 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
I had the patience and resoldered all 50 or so wires, i would rather have done the wire harness route if i had a chance to do it again.
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 09-27-2002, 10:39 PM
amy@af's Avatar
in a perfect world...Si would be the (usdm) base model
Old 09-27-2002, 11:08 PM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
Yo, I don't remember where I read it, but I know I did.... isn't there an issue with the DX throttle cable being too long also? If so, the required one would be an Si throttle cable?
Anyone know where to get a DX - D16Z6/Y8 conversion wiring harness at?
Honda Enthusiast
Old 09-27-2002, 11:18 PM
gunnmen01's Avatar
thedropshop.tv, or go to Amis page and check the links section.
Old 09-27-2002, 11:19 PM
slammed89civic's Avatar
slammed89civic slammed89civic is offline
Send a message via AIM to slammed89civic Send a message via Yahoo to slammed89civic
the guy who did my install did it for 20 bucks and a 12 pack.....lol...i dropped the engine, he did all the electrical shit, he is also is a good friend...so thats why it was so cheap, all it all my total cost was 600 plus the price of a d16a6 dizzy
Old 09-27-2002, 11:23 PM
amy@af's Avatar
dropshop or you can e-mail jason ([email protected]) he did mine and a couple of other people's. either place is going to be $150
Old 09-27-2002, 11:48 PM
Killa_CRX's Avatar
When Civics Attack!
oh, so by wiring harness you mean instead of having the wires resoddered, putting together two connecting ends with which to plug the DX and the sohc vtec ECU together?
Honda Enthusiast
Old 09-28-2002, 12:54 AM
91civicDXdude's Avatar
You can use the throttle cable of off any 4th gen model that has multi point fuel injection stock. I used the cable off of a CRX HF and it works fine.
One thing also when you do the swap you'll notice that some of the hoses and wires wont have the same mounting brackets so you might have to fabricate them.
One other thing, if you're not using the p28 ECU, you have to use a distributor from a car that came stock with multi point because those have the cylinder position censor inside and the DX distributor does not.
Whats needed for this engine swap. 4cyl to 5.0 Wuzzube Mustang Talk 0 11-15-2004 07:46 PM
89 Teg. LS swap vs. SOHC VTEC swap cornbread499 '88 - '91 Civic | CRX | Wagon | Shuttlee 3 06-24-2003 09:21 PM
Parts for Sohc vtec head swap walt0023 '88 - '91 Civic | CRX | Wagon | Shuttlee 8 12-02-2002 10:19 PM
SOHC VTEC swap pics 91civicDXdude '88 - '91 Civic | CRX | Wagon | Shuttlee 15 09-09-2002 01:15 AM
