Old 10-19-2002, 12:26 AM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
swap info needed
my a6 even after the head job is being gay, i know i still need to get my timing fixed and all but im really starting to want a d-series swap i have an si and i can use my tranny and alls i have to do is buy the ecu and engine and mounts....i dont even know if i need the mounts.......anyone help? i know its probably been posted before but hey call me lazy lol, any kind of help will be appreciated, and i want to boost it after a while too or i been thinkin about building the a6 after i get the y8 or z6 * i think thats it* in there and just build the a6 for boost
2002 Acura TL Type S
1991 Honda Crx Si
Old 10-19-2002, 11:15 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
the engine section has links with swap info
http://www.4thgenerationcivic.com/engines/Engines.htm
you can use your tranny and motor mounts. you can even use your ecu. however, the best way is to use a p28 ecu (92-95 Si/EX)
go to dropshop for turbo. tel him what you want to do and he'll tell you the best way to do it. you can get an engine from him as well
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 10-19-2002, 08:44 PM
thanx ami
1991 Honda Crx Si
Old 10-19-2002, 09:41 PM
amy@af's Avatar
never a problem. i have the y8 in my si. if you have any questions you can always pm or e-mail me.
good luck!
Old 10-19-2002, 09:56 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
And i have the Z6 swapped in, theres quite a few peeps that have a d series swap...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 10-19-2002, 11:33 PM
well i did want a gsr, but since im not that wealthy and i like a challenge i decided i want a y8 or a z6 and see what kinda of numbers that i can get with that, what do you run ami? and gunnmen?
1991 Honda Crx Si
d16z6 swap info needed! BiGwiLLswiLLy Engineering/ Technical 3 09-02-2003 01:27 AM
H22 Swap .... info needed Accord823 Engineering/ Technical 0 07-18-2003 05:11 PM
Ls to vtec swap info needed NhGreenTeg Integra 9 04-15-2003 05:06 PM
88 Cav Engine Swap Info Needed frag_geiss Cavalier 1 10-03-2002 09:52 AM
'91 Si b18 swap info needed PFCfutrell Engineering/ Technical 3 04-13-2002 12:29 PM
