Old 04-07-2002, 04:49 PM
PFCfutrell PFCfutrell is offline
Send a message via AIM to PFCfutrell Send a message via Yahoo to PFCfutrell
'91 Si b18 swap info needed
what all do i need to swap an '90 LS motor into a '91 CRX SI? I can get the motor/tranny for cheap I just want to make sure it won't be too expensive to get the rest.
1991 CRX SI (black)
15.3 @ 88mph (stock motor)
'90 B18A1 swap
Custom exhaust
*2.25" piping
*two glasspacks (inline)
*polished flash-cut tip
*exits pass. side, front of rear tire.
'95 GSR 15" wheels
195/50/R15 Bridgestone Potenza SO-3's
AE Eng. front crossmember
Susp. Tech. 22mm rear sway bar
Susp. Tech. 1.8" lowering springs
Tokico Illumina 5-way adj. shocks
Powerslot rotors
Metal Master pads
Goodridge steel-braided brake lines
Red painted OEM calipers
Skunk2 short shifter
Skunk2 shift knob
GT Grant steering wheel
Red/black racing seats
Old 04-08-2002, 10:14 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: '91 Si b18 swap info needed
Lets see.. its about the same as swappin the b16 or any other b-series motor. Custom mounts (hasport, HCP , Place racing ) , shift linkage (hasport, HCP , Place racing ) , 90-93 integra axles, 90-93 integra ecu and thats about it. Oh you need the intermediate shaft if the motor doesn't come with one.
Old 04-12-2002, 09:53 PM
EightOhOne's Avatar
EightOhOne EightOhOne is offline
also, keep your Si harness, and plug that into the ls engine. Its all plug and play with the 90-91 LS's. If you can get the teg linkage, you just need to shorten it a little bit, its not really necessary to spend 200 on custom linkage. get your measurement, and take it to a welding shop, its like five minutes of work.
Old 04-13-2002, 12:29 PM
a friend of mine can customize the shift linkage for free, and i've got the hookup for polyuerethane (sp?) mounts for $195.
1991 CRX SI (black)
'90 B18A1 swap
Custom exhaust
*2.25" piping
'95 GSR 15" wheels
Powerslot rotors
Metal Master pads
Skunk2 shift knob
d16z6 swap info needed! BiGwiLLswiLLy Engineering/ Technical 3 09-02-2003 01:27 AM
H22 Swap .... info needed Accord823 Engineering/ Technical 0 07-18-2003 05:11 PM
Ls to vtec swap info needed NhGreenTeg Integra 9 04-15-2003 05:06 PM
swap info needed civicHBsi91 '88 - '91 Civic | CRX | Wagon | Shuttlee 5 10-19-2002 11:33 PM
88 Cav Engine Swap Info Needed frag_geiss Cavalier 1 10-03-2002 09:52 AM
