Old 10-12-2002, 01:43 AM
ndekens ndekens is offline
Question 95 civic ex engine questions
I have a 95 civic ex with a d16z6 that im planning on turning into a sleeper. Since I know little about honda engines, is the d16z6 a respectable engine worth rebuilding and adding aftermarket parts to or would I be better off swapping out the engine? If so what engine would I swap in?
Thanks
Old 10-12-2002, 01:55 AM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
nope, your motor won't be good for what you're looking for. Definately go for a swap. I would recommend a B18C1 out of an Acura Integra GSR
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 10-12-2002, 02:00 AM
oh yeah, and welcome to AF
2000 BMW 323IT
1954 Ford F100
Old 10-12-2002, 10:50 AM
91civicDXdude's Avatar
there are many single cam hondas that are in the 12's. It all depends on what you want to do. anybody can go fast in a b series car but what do you say when your b series gets beat by a tuned d series?
Old 10-12-2002, 12:43 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
your d16z6 is fine for building up! you can build what is called a "junkyard" turbo. it is made up of talon/eclipse turbo and other parts. can run 10-14 psi and it will run you around $2000 to hook up.
here is a 12 sec 88 DX (turbo his d15b2 sohc non vtec)
link
here is a link with more info on a junkyard:
junkyard link
dropshop can custom weld it up for ya:
dropshop boost
all you ever hear is the trendy "b series"...don't let anyone ever try and tell you the d series is junk. just because it isn't trendy and the engine comes stock doesn't mean it's no good/junk
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 10-12-2002, 04:13 PM
yes, you can make that engine run 12s. But wouldn't it be a lot easier to start with a 170 hp, 128 ft/lbs of torque engine instead of a 125 hp, 106 ft/lbs of torque engine.
2000 BMW 323IT
1954 Ford F100
Old 10-12-2002, 04:23 PM
Then which engine would be better to put a supercharger on? the b18 or the d16?
Old 10-12-2002, 04:43 PM
amy@af's Avatar
not in IMO. it's easier to leave the stock engine in and turbo. it's also cheaper. not only would it be cheaper to turbo than to swap in a b series but, it is also cheaper for d than b series aftermarket parts. go price a clutch, header, cams (or cam gears), or any other part. costs much more.
i don't know about you, but when it comes to my race car i don't care about name brands. i'd rather take pride in my little set-up which costs half as much and still get the job done.
Old 10-12-2002, 04:52 PM
amy@af's Avatar
Originally posted by j.fuggi
there's no way in hell you can run 10-14psi off a homemade turbo. you need FMU, forged internals, maybe 5psi safely on stock bottom end.
slow down and read. i said you can build off that turbo and other parts. that is including turbo mani, intercooler, blow off valve, injectors, hondata (or vafc), and so on.....i obviously wouldn't buy just a T25 turbo for $2000.
Old 10-12-2002, 05:25 PM
Ok, let's be cheap while building a sleeper
2000 BMW 323IT
1954 Ford F100
Old 10-12-2002, 08:49 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
cheap or not it gets the job done like ami said
2002 Acura TL Type S
1991 Honda Crx Si
Old 10-13-2002, 12:26 AM
I'd rather have name brand, quality, realiable items on my car, not junk from a yard.
2000 BMW 323IT
1954 Ford F100
Old 10-13-2002, 03:38 AM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
I don't believe in name brand either... after all... I have heard more complaints about name brands like Jackson Racing Superchargers then you could shake a stick at!
Don't forget.... Pacesetter is a well known name brand too... but would you have any of their products on your car?
Name brands aren't always best!
yea you can get a very cheap home made turbo, but don't expect your untuned motor to run too well over 5-6 psi. if you beef up the internals, of course you can up the boost, but there's no way in hell a sohc motor can handle excessive boost. a FMU will halp it along, but not for long without building the motor.
Did you read that article about that 88 Civic DX? Is pretty cool!
You don't have to start the motor off running 10-14psi directly... could start off with 5-6, and as you build your motor up the pressure could be increased...
In the end, less money would still be spent then swapping in a Bseries motor, and trying to build it up and the Dseries would be running just as fast!
Plus you'd be able to to tell people "Bseries? I don't need no stinkin' Bseries!"
Honda Enthusiast
Old 10-13-2002, 11:42 AM
amy@af's Avatar
the only thing out of a junkyard is the actual T25 and 9 times out of ten you get it used from somebody and not out of an acutal junkyard.
j.fuggi too.
it's a real trend to roll around un-tuned. give me a break. ANY car with ANY set-up won't run well if it isn't tuned.
ndekens, read the links i sent. i know for a fact dropshop ran and is running his set up just as it says on that site. you should e-mail him. he'll give you ALL the options. not just the trendy ones....
2009 civic engine in a 95 Crazy667 JDM Motor & Parts info/chat 5 06-27-2016 02:12 PM
Trying to learn engines dingaling15 How-To's and Walk-Through's 2 12-18-2011 08:17 PM
2005 Hybrid with recurrent engine/IMA lights SheltieMan '01-'05 Civic 1 07-14-2010 08:54 AM
Civic Hybrid Cars-- '06+ Civic 0 05-04-2009 07:30 AM
92 civic engine......questions..... slammed89civic '88 - '91 Civic | CRX | Wagon | Shuttlee 9 07-07-2002 12:19 PM
